misterwiley Posted February 23, 2018 Share Posted February 23, 2018 I'm looking into building a custom gate that operates as a normal door in Chief. Are there any tutorials out there that y'all know of? Link to comment Share on other sites More sharing options...
RL-inc Posted February 23, 2018 Share Posted February 23, 2018 Might try a search on this forum. Creating symbol from P-line solids is pretty straight forward. Link to comment Share on other sites More sharing options...
RL-inc Posted February 23, 2018 Share Posted February 23, 2018 Have you tried just placing a door in railing wall and editing as a normal door Link to comment Share on other sites More sharing options...
misterwiley Posted February 23, 2018 Author Share Posted February 23, 2018 Thank you! I hadn't realized you needed to create a symbol of your p-solid and then that could be turned into a door. I was trying to get my p-solid to work as a door with the "convert to" or the "add to library" tools without luck. Just missed a step. Cheers! Link to comment Share on other sites More sharing options...
Kbird1 Posted February 23, 2018 Share Posted February 23, 2018 Chief has a couple of Videos that show very basically the technique use with PolySolids , they make a couple of Rangehoods... https://www.chiefarchitect.com/videos/watch/10151/creating-custom-objects-polyline-solid-hood-symbol.html https://www.chiefarchitect.com/videos/watch/10150/creating-custom-objects-molding-polyline-hood-symbol.html 1 Link to comment Share on other sites More sharing options...
dshall Posted February 23, 2018 Share Posted February 23, 2018 The key is designing the door a little smaller than the opening (for a gate). One way to do this is to place a very small PSOLID just outside of your door and then turn it into a symbol. This creates the gap. Maybe another option w0uld be to change the bounding box of the door? Maybe? Eric? Michael? 1 Link to comment Share on other sites More sharing options...
dshall Posted February 23, 2018 Share Posted February 23, 2018 On 2/23/2018 at 3:43 PM, solver said: Why does it need to be smaller? Expand Because there is usually a gap between the fence and the post. Think about a wrought iron gate, no casing, there is a gap between gate and fence. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 23, 2018 Share Posted February 23, 2018 On 2/23/2018 at 2:56 PM, dshall said: The key is designing the door a little smaller than the opening (for a gate). One way to do this is to place a very small PSOLID just outside of your door and then turn it into a symbol. This creates the gap. Maybe another option w0uld be to change the bounding box of the door? Maybe? Eric? Michael? Expand Yes. You can do it that way if you want to. Just make the bounding box slightly taller and wider than the door. You are in essence telling Chief that "I want the object's geometry to display at its full original size when I set the dimensions to this...." Link to comment Share on other sites More sharing options...
