pgjacob Posted February 21, 2018 Share Posted February 21, 2018 Hi All I have three questions...y'all have been so helpful, so I give you a 3 for one deal today! 1) I am trying to create seams in hardie siding. I have attached the reference photo (grey area). The Hardie material is already in the catalog, and it "paints" well with no seams, which is usually how I prefer, but in this case I need to create the seams and see each individual panel. I tried to alter the material definition, and I created a new material with a border but both didn't work well. 2) Also, this same photo shows cedar panels that are thicker than the Hardie. The cedar is on it's own floor, so these areas are already separated by floor. I tried having a thicker wall type but the walls were skewed (one jutted out). I see in material definition that there is a thickness area available,but it doesn't seems to change visually. 3) Finally, the windows in the photo are really reflective. I like this effect. I am not seeing this in my ray trace so (after a suggestion from tech support) I put a polyline in front of the building and painted a backdrop to give the windows something to reflect but it didn't work so well. Then I had to learn about refractive index from Wikipedia, and I had to take a nap. Can I get the windows to reflect more? Water is more reflective than diamond? Or vice versa... Any suggestions? Thanks in advance melissa Link to comment Share on other sites More sharing options...
robdyck Posted February 21, 2018 Share Posted February 21, 2018 1) to get the seams correct, you'll need to do virtually what the siding installer would do...cut and install individual pieces! Material regions or p-solids. Not what you wanted to hear but I've been there. 3) window reflections are the source of my premature grey hair! Trial and error... Link to comment Share on other sites More sharing options...
Kbird1 Posted February 21, 2018 Share Posted February 21, 2018 As for the Cedar it will depend on the Wall definition and how the two walls Align ...they usually Align over the "Main Layer Outside" , ie usually the Framing , so just making the wall thicker won't work unless you "resize about Inner Surface" perhaps. ( Alt-Q Shortcut key) Will they be aligned in real life? (RL) if yes then build your wall layers as in RL, ie the Hardi will be mounted on 1/2 thick Treated Battens usually (Rain-screen) , there should likely be a Flashing detail between them too. I hope your Client realizes Cedar requires ALOT of maintenance , it looks great for the 1st 2-3 years but tends to take a beating with UV, Rain etc as it can move dramatically in different weather conditions..... M. Link to comment Share on other sites More sharing options...
RL-inc Posted February 21, 2018 Share Posted February 21, 2018 Regarding the Hardi - panel see attached. I made it for metal but easy enough to revise. I used a brick pattern and the CA plywood texture - adjusted both sizes to fit my needs. METAL PANEL.calibz Link to comment Share on other sites More sharing options...
rlackore Posted February 21, 2018 Share Posted February 21, 2018 Here is my HardiePanel stuff: HardiePanel.calibz Smooth - Stucco - Cedarmill The diffuse maps are grayscale, so you can easily apply colors. The 4x8 panel is created with a bump map, and the texture with a normal map. Not perfect, but not horrible. Link to comment Share on other sites More sharing options...
RL-inc Posted February 21, 2018 Share Posted February 21, 2018 Looks great to me Robert Link to comment Share on other sites More sharing options...
pgjacob Posted February 21, 2018 Author Share Posted February 21, 2018 I agree looks great. I downloaded but can't find it in my user catalog...I also downloaded RL-inc's metal panel and it showed up in the user catalog... any suggestions? But I had JUST finished making my own panel and then this reply came in. I did a combination of wall material regions (multiple copy including a gap) and then took a snip of this in PBR, and used as a material to paint entire exterior. Then used wall material region for cedar to make thicker. I think turned out pretty nice, but now I would like to try rlacklore's panels.... As always, great help here. Link to comment Share on other sites More sharing options...
rlackore Posted February 21, 2018 Share Posted February 21, 2018 On 2/21/2018 at 7:27 PM, pgjacob said: I agree looks great. I downloaded but can't find it in my user catalog... Expand They should import - don't know why they wouldn't. Here are their names: Link to comment Share on other sites More sharing options...
Kbird1 Posted February 21, 2018 Share Posted February 21, 2018 On 2/21/2018 at 7:40 PM, rlackore said: They should import - don't know why they wouldn't. Here are their names: Expand Thanks again Robert , looks good , they imported fine here to my User Library ( they aren't in a HardiPanel Folder Melissa, if that's what you looked for? ) M. Link to comment Share on other sites More sharing options...
pgjacob Posted February 21, 2018 Author Share Posted February 21, 2018 Yes, got it! I restarted and re-downloaded. But I have it. Thanks! Link to comment Share on other sites More sharing options...
