atomic12 Posted February 19, 2018 Share Posted February 19, 2018 I am having an issue when I use the concentric option, the concentric icon is hitch hiking on the arrow pointer. Even if I click on the concentric tool, it does not go away. My question is, How do you go back to the arrow pointer only without seeing the side kick? Probably so simple, but very annoying. Thanks in advance Link to comment Share on other sites More sharing options...
Chrisb222 Posted February 19, 2018 Share Posted February 19, 2018 Hit D Returns you to Default pointer. Or go to Edit > Edit Behaviors > Default Link to comment Share on other sites More sharing options...
atomic12 Posted February 19, 2018 Author Share Posted February 19, 2018 Well, that was easy. I wish all you had to do is hit the arrow again to go back, but I will make a note of this and go have a beer. Thank you. Link to comment Share on other sites More sharing options...
Kbird1 Posted February 20, 2018 Share Posted February 20, 2018 46 minutes ago, atomic12 said: I am having an issue when I use the concentric option, the concentric icon is hitch hiking on the arrow pointer. Even if I click on the concentric tool, it does not go away. My question is, How do you go back to the arrow pointer only without seeing the side kick? Probably so simple, but very annoying. Thanks in advance Click on the Default Tool to release it or Use Alt+Z ......... I think Chris has changed his default Hotkey for it to D , which you could do too of course..... M. Link to comment Share on other sites More sharing options...
atomic12 Posted February 20, 2018 Author Share Posted February 20, 2018 Thanks guys. These little annoyances that is hard to find in the overall world of Chief. Again, thanks for the help. I never did like to picking up hitch hikers. Link to comment Share on other sites More sharing options...
atomic12 Posted February 20, 2018 Author Share Posted February 20, 2018 Hmmm... spoke to soon. Alt Z did not do squat.... Must be a hot key for that also Link to comment Share on other sites More sharing options...
Kbird1 Posted February 20, 2018 Share Posted February 20, 2018 Check your Hot Keys then cos Alt+Z is the default unless changed in x10 but I use the Default Tool Icon, I put on the Toolbar next to the Dropdown list usually and it says Alt+Z if I hover over it..... Link to comment Share on other sites More sharing options...
Kbird1 Posted February 20, 2018 Share Posted February 20, 2018 It seems Hotkeys are not working for that in x10.....Alt+ Z doesn't work though assigned to it , so I changed it to D and it still doesn't work , the Default Icon does though.... Bug? Link to comment Share on other sites More sharing options...
atomic12 Posted February 20, 2018 Author Share Posted February 20, 2018 Thank you,,, a new challenge in life that nobody has time for. But I do appreciate you checking it out on 10 cuz that's what I am running and it does not seem to work even trying Alt / Link to comment Share on other sites More sharing options...
Kbird1 Posted February 20, 2018 Share Posted February 20, 2018 Happy to Help ....sort of , not really only the Icon is working for me to turn it off too.... , I guess we both need help Also, it's good to have your Forum Signature filled in please, especially with the Software Version, and of course a Name is nice too ..............see mine below in Blue for how to do that. If you don't see my Signature then you have them turned off for the Forum or are perhaps on the CA Mobile WebSite. Link to comment Share on other sites More sharing options...
glennw Posted February 20, 2018 Share Posted February 20, 2018 When assigning the shortcut in Customize Hotkeys, are you pressing Alt and Z at the same time or one after the other? Link to comment Share on other sites More sharing options...
Kbird1 Posted February 20, 2018 Share Posted February 20, 2018 Alt+ Z is the Default Hot Key for the Default Edit Mode already according to the Hot-Key Table but neither of use can get it to work so we are both doing something in the wrong sequence or time as the Default Edit Mode Icon disables Concentric as expected. I tried assigning D instead as Chris mentioned and it's doesnt enable Default again either , so I figure I am doing it wrong ....I usually just use the Icons , never been a Hotkey User so figure I am doing it wrong? M. Link to comment Share on other sites More sharing options...
atomic12 Posted February 26, 2018 Author Share Posted February 26, 2018 Thanks Guys... I did get it working but had to use the hot keys. Link to comment Share on other sites More sharing options...
dshall Posted February 26, 2018 Share Posted February 26, 2018 On 2/19/2018 at 8:09 PM, Kbird1 said: Alt+ Z is the Default Hot Key for the Default Edit Mode already according to the Hot-Key Table but neither of use can get it to work so we are both doing something in the wrong sequence or time as the Default Edit Mode Icon disables Concentric as expected. I tried assigning D instead as Chris mentioned and it's doesnt enable Default again either , so I figure I am doing it wrong ....I usually just use the Icons , never been a Hotkey User so figure I am doing it wrong? M. I do not think it is good to use one letter for hot key. that letter D may be used for a multiple hot key.... D+H, think about it, if D is tied to a multiple key, the solo D will never work. I would always use at least two keys for a hot key. BTW, I have a hot key assigned to both of those function in post #1 that would of removed the "hitchhikers". 1 Link to comment Share on other sites More sharing options...
atomic12 Posted February 26, 2018 Author Share Posted February 26, 2018 DsHall, long time... no more You Tube videos? Anyway, the default is not the default do to no fault of us. Chief should give finder fees when we discover a glitch. Maybe a discount code to hooters magazine.. Link to comment Share on other sites More sharing options...
Kbird1 Posted February 26, 2018 Share Posted February 26, 2018 1 hour ago, dshall said: I do not think it is good to use one letter for hot key. that letter D may be used for a multiple hot key.... D+H, think about it, if D is tied to a multiple key, the solo D will never work. I would always use at least two keys for a hot key. BTW, I have a hot key assigned to both of those function in post #1 that would of removed the "hitchhikers". I need to have another play as unlike you I am not a big hotkey user but I could not get this one to work at Default ( Alt+Z ) , I thought perhaps I was hitting Alt to ealy so nothing happened so assigned D as Chris mentioned and that didn't work either , so I just use the Default Icon On put on the Side Toolbar which does work. Could well be Pilot Error of course since Hot-Keys are not my Forte. M Link to comment Share on other sites More sharing options...
glennw Posted February 27, 2018 Share Posted February 27, 2018 11 hours ago, dshall said: I do not think it is good to use one letter for hot key. that letter D may be used for a multiple hot key.... D+H, think about it, if D is tied to a multiple key, the solo D will never work. I would always use at least two keys for a hot key. Sort of... The solo D will preclude any other hotkeys from using D as the first letter - so the D will work, but when you try to assign, say D,A, you will get an error message. If you assign one letter to a hoykey (say D), it precludes using any other combinations like (D,A). This drastically reduces the number of hotkeys you can assign. I am talking about sequential hotkeys, not simultaneous hotkeys. Link to comment Share on other sites More sharing options...
