CA X10 AUTOSAVE NOT WORKING
ChiefCody
Back in Version 6, circa 1999 I stopped depending upon "Auto Save". No one is responsible for your work and produce but you, so I, in this case, manually save (CTRL -S or F3) every few seconds as I work to make sure I do not lose my work. If I have a crash or autosave fails, my work is saved within a few seconds. You should consider doing this as well. Chief Tech Support cannot return your lost work, so you need to be more personally responsible for that yourself.
  • 4 weeks later...
I am having the same issue. I can work for several hours, and find that auto save has not been working. I tend to save my file myself on a regular basis, but sometimes I have needed to rely on auto save only to find it hasn't saved anything.
If this is happening in a Named File you should Report it to Tech Support to be addressed for the next Update.....
as Noted above if you Open a New Plan always Name it Immediately before starting Drawing or Autosave will not work...
Also, it's good to have your Forum Signature filled in please, especially with the Software Version,
and of course a Name is nice too :) ..............see mine below in Blue for how to do that.
If you don't see my Signature then you have them turned off for the Forum
Toggle it on in UserName>Account >Signatures...... go to the Upper RH Corner of Forum Window.
I ALWAYS do my own "save as"
I don't rely on Chief
I spent 30 years as a Systems Analyst/Programmer and I rely on myself
One or two times I've needed to find a plan in the archives
usually after I'm working on a plan and get distracted and come back hours later or even the next day
Lew
Lew
+1, this is me.
I turned auto save off immediately after starting out with Chief.
Sometimes I don't want to save, and I don't want auto save saving something I don't want saved.
Hitting Command-S is too easy, and 30 years in the computer design business, back before Auto Save or Archives, teaches you the hard way to SAVE SAVE SAVE
Chris:
not sure you can turn autosave off totally ???
maybe now it can be - but versions ago it couldn't
I set it for minimal saves and just let it do it's thing
there have been a few times where I have need to use an archived version
very rare
I do my own saves - sometimes every few minutes if I am completing a task I don't want to do again
I do a double "save as"
the first has the date and time as part of the file name - this is for backups
the second is to the primary file names - this keeps layout and plan in sync
and allows me to go to a backup if needed
I have undo set for 5 - beyond that I can't really keep track what I was doing and want to undo ;)
BACKUP FILE NAME:  123_OAK_REMOD_180317_1710_LBX10.plan
remod or model or alto1 etc
for layout LAYPS or LAYCP - ps = permit set   cp = client presentation
PRIMARY FILE NAME:  123_OAK_REMOD_LBX10.plan and 123_OAK_LAYPS_LBX10.layout
doing a double save takes seconds and works very well for me
Lew
Yes. Preferences > File Management. Uncheck "Auto Save."
Good idea, I might start doing this.
Would be nice if you could instruct Chief to auto Date-Time stamp the file name...
It does it for Autosaves in the Archive Folder... I have it set for Hourly  and AutoSave set for 5 mins in case there is a Crash too, but I am also saving as I work , hitting the Save Icon every now and then or when I stop for a Break ( Forum Read :) ).
15.thumb.JPG.c37997a36e5b89be1d1074e70b50bbfe.JPG16.thumb.JPG.7c04d2f411eb5be9ef45ff5dbfb992ef.JPG
