tim722 Posted January 18, 2018 Share Posted January 18, 2018 Please refer to attached images. I'm pondering how to do something along these lines in CA using X8. Assuming the following. Beam pockets in walls for the larger beams. layers for roof over interior structure include usual OSB with paper and corr. metal, and ceiling to int. roof with gyp board. I've tried different techniques and can't quite get there. Do you do deck/porch room and create a custom roof structure? Manually place beams and create an "elevated deck" for the porch covering? I'm sure there are some advanced techniques I'm not aware of to accomplish this. Can someone take a look and suggest a workable solution? Thanks! Link to comment Share on other sites More sharing options...
javatom Posted January 18, 2018 Share Posted January 18, 2018 Manually create a roof plane with structure defined by thickness of sheathing. Place posts, beams and rafters as required. You would not be doing an automatic roof here. Your room definition should have roof and ceiling shut off. There are other ways of doing this, but this method will give you the greatest degree of control. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted January 18, 2018 Share Posted January 18, 2018 I would try this using the deck tool, No railing, on the 2nd floor weather you have one or not, that's how I do lattice patio covers, at least you can adjust the deck layers and spacing to what you want. Easy to change joists direction also.. There might be some fix up but a lot faster than using p-solids. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 18, 2018 Share Posted January 18, 2018 it looks similar to the Carport KB Article and several others like the one on Barns.... To fill in your Forun Signature , please see mine for how to do it...thanks. https://www.chiefarchitect.com/support/article/KB-01179/creating-a-carport.html https://www.chiefarchitect.com/support/article/KB-00598/creating-a-post-and-beam-structure.html https://www.chiefarchitect.com/support/article/KB-01069/designing-a-traditional-pole-barn-structure.html https://www.homedesignersoftware.com/support/article/KB-00889/creating-a-custom-pergola.html https://www.homedesignersoftware.com/support/article/KB-01010/creating-a-covered-patio.html Link to comment Share on other sites More sharing options...
tim722 Posted January 19, 2018 Author Share Posted January 19, 2018 Thanks everyone for the info. The ideas about using the generated lookouts as purlins is what got me going in the right direction. At this point I'm drawing my roof plane, adding a 1 1/2" air space above my rafter to make room for the purlins. Roof surface is corr. steel panels. Once the roof shapes and overhangs look good, I turn off auto roof, select all lookouts on one edge and delete. Select lookouts on other edge, raise height by 1 1/2", and extend all the way across the roof plane. The only issue I see is not being able to grab all "purlins" at once and extend them. Each one has to be done in turn. See attached. Link to comment Share on other sites More sharing options...
Chopsaw Posted January 19, 2018 Share Posted January 19, 2018 2 minutes ago, tim722 said: The only issue I see is not being able to grab all "purlins" at once and extend them. Each one has to be done in turn You should be able to marquee select the purlins in a rafter cavity and extend them to the edge of the selected roof plane all at once without too much of a problem. Sorry to have not seen your post earlier but it looks like you have it working for you. I am hoping to finish and release a toolset for this purpose that will provide a little more automation to the process sometime soon but I have been really busy. Link to comment Share on other sites More sharing options...
tim722 Posted January 19, 2018 Author Share Posted January 19, 2018 I did figure out another way. (maybe quicker). Auto generate roof, then turn off auto roof. Delete all except one lookout in plan view. Move to desired location in plan view. (lookouts don't go to edge of rafter at eaves. Extend, multi-copy up the roof plane, raise height, done! Thanks again. Chopsaw, looking forward to see what you have going on with the toolset. Link to comment Share on other sites More sharing options...
Chopsaw Posted January 19, 2018 Share Posted January 19, 2018 Yes that would work fine on a gable roof. Good thinking. Are you new to the software or just the forum ? Send me a PM if you have another similar project. Link to comment Share on other sites More sharing options...
tim722 Posted January 19, 2018 Author Share Posted January 19, 2018 Newer to the forum, but still new to the software also. I had bought it to work on the house I'm going to build. I'm on about my 5th floor plan, and it looks like it may still be a while before the house gets built. Just practicing/learning in the meantime. Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 19, 2018 Share Posted January 19, 2018 Link to comment Share on other sites More sharing options...
