tim722
How would you do this roof in CA
Please refer to attached images.
I'm pondering how to do something along these lines in CA using X8.
Assuming the following. Beam pockets in walls for the larger beams. layers for roof
over interior structure include usual OSB with paper and corr. metal, and ceiling to int. roof with gyp board.
I've tried different techniques and can't quite get there.
Do you do deck/porch room and create a custom roof structure? Manually place beams and create
an "elevated deck" for the porch covering? I'm sure there are some advanced techniques I'm not
aware of to accomplish this.
Can someone take a look and suggest a workable solution?
Thanks!
Manually create a roof plane with structure defined by thickness of sheathing.  Place posts, beams and rafters as required.  You would not be doing an automatic roof here.  Your room definition should have roof and ceiling shut off.  There are other ways of doing this, but this method will give you the greatest degree of control.
A forum search for purlin will return lots of good info.
I would try this using the deck tool, No railing, on the 2nd floor weather you have one or not, that's how I do lattice patio covers, at least you can adjust the deck layers and spacing to what you want. Easy to change joists direction also.. There might be some fix up but a lot faster than using p-solids.
Thanks everyone for the info. The ideas about using the generated lookouts as purlins is what got
me going in the right direction. At this point I'm drawing my roof plane, adding a 1 1/2" air space
above my rafter to make room for the purlins. Roof surface is corr. steel panels.
Once the roof shapes and overhangs look good, I turn off auto roof, select all lookouts
on one edge and delete. Select lookouts on other edge, raise height by 1 1/2", and extend
all the way across the roof plane. The only issue I see is not being able to grab all "purlins"
at once and extend them. Each one has to be done in turn.
See attached.
You should be able to marquee select the purlins in a rafter cavity and extend them to the edge of the selected roof plane all at once without too much of a problem.
Sorry to have not seen your post earlier but it looks like you have it working for you.  I am hoping to finish and release a toolset for this purpose that will provide a little more automation to the process sometime soon but I have been really busy.
I did figure out another way. (maybe quicker).
Auto generate roof, then turn off auto roof.
Delete all except one lookout in plan view.
Move to desired location in plan view. (lookouts don't go to edge of rafter at eaves.
Extend, multi-copy up the roof plane, raise height, done!
Thanks again. Chopsaw, looking forward to see what you have going on with the toolset.
Yes that would work fine on a gable roof. Good thinking.  Are you new to the software or just the forum ?  Send me a PM if you have another similar project.
Newer to the forum, but still new to the software also. I had bought it to work on the house I'm going to build.
I'm on about my 5th floor plan, and it looks like it may still be a while before the house gets built.
Just practicing/learning in the meantime.
    27469
    THDesign
    THDesign
  • Similar Content
    • By 9atatimer
      I'm using X11 premier on a mac -- I have an exterior garage wall (with a centered garage door) and a gable end -- I'd like to split the attic wall of the gable end into 3 parts -- the central region above the garage door, and the left and right, to have a different material above the garage door.
      I have Default Settings > Roof > Auto Rebuild Roof set to Off
      I have Default Settings > Framing > Automatically Build Floor and Ceiling Framing Off on all framing types.
      I have Default Settings > Walls > General Walls > Auto Rebuild Attic Walls set to Off
      If I delete the roof and ceiling planes with Build > Roof > Delete [X] and then use the Build > Roof > Build Roof ... dialog to rebuild the roof and attic from scratch -- I leave the Auto Rebuild Roofs set to Off, to be clear -- and then edit the resulting gable roof on the attic layer, I can split it twice to produce the three separate wall sections, but once I change the exterior material on any of the sections, the three wall segments get replaced with a single wall again.  The new wall has my selected material, but that does me no good as I need the distinct secgments.
      Anyone know what setting do I need to turn off to maintain the manually edited gable end?  Or is this a mac bug?
      Or, barring that, does anyone know what approach will let me give the desired finish detail (attached a pic of a freehand elevation)?
    • By blueriver
      I'm using Chief Architect Premier X11
      I have all these little 'X's can someone please tell me how to get rid of them?  I've been really playing around with the roof and i THINK they are from that but at the same time i have a couple random ones outside where the roof is -- i cannot get them to go away. Help!
      thanks in advance
      Lauren
    • By chief69
      Hello, We are having a hard time getting  the design program to do the roof right. We have tried with Sketchup and it got the closest. It's hard to describe I have attached a few pics with a decent idea of what we are trying to do.
      The Garage is a shed roof as well as the breeze way, but they are at different angles. The house is a butterfly style with the V running at a angle. WE do not care what the pitch ends up being on any of the roofs.
      Anyone know how to do this. I have been trying for hours and the program goes crazy every time. Esp with the all 3 roofs at different angles with each other. I have attached a copy of the plan we made and some pics from sketchup because that program got the closest to what we are trying to do.
      Thanks
      Chris
      New house v1.plan
    • By MN_JohnH
      I wonder why my second floor loft flooring is sticking through the roof and can be seen on the outside of the building?
