TSarantopulos
Shiny COPPER
I'm somewhat stumped why this isn't working. I'm trying to create shiny copper on a hood over a range.  I've used "shiny copper" as the material and have even changed the material properties to be "shiny metal" for the ray trace.  I just cant get it to render shiny, its just flat.  Suggestions please?
Sometimes you need to add a light source near something you want to highlight.
Unfortunately, the Bonus Metal Library doesn't have Shiny Copper, just hammered, heated, ground and brushed.  Why not shiny?  It's used on gutters, roofs and other building elements.  We need shiny!
It would help if you gave us a screen shot of your unsatisfactory results.
Here are a couple of stock items from the Library Browser with their
materials set to: Core Catalogs/Materials/Metals/Copper/Polished.
They look "shiny" to me. :)
  • Upvote 2
You can make anything as shiny/reflective as you want using the "Adjust Material Definition" tool.
Vase with stock Polished Copper material:
Same material after material adjustment:
I would suggest copying the Stock Copper Polished Material too your User Library , renamed it Shiny Copper and then do the material definition Change on it in the library so you will always have it to reuse and can try different looks.....
I'm trying to reproduce your output.  What material adjustments did you make to the copper if any?  What were your RT settings?  I just can't get even close to that output.
I didn't save the original plan but it's easy to reproduce.
I made a room from 4 interior walls and placed a table
(Iron Frame Table) and vase (Sphere Vase) from the
Library Browser into the room (Image-1). I changed the
interior wall material from Drywall to the color Sand and
changed the material of the table frame and vase to Copper
Polished (Image-2). Image-3 shows the material settings
for Copper Polished. Image-4 shows the Ray Trace and
Image Property settings and Image 5 is the final cropped
image.
Make sure in RT settings, on the "Advanced" tab, that "Use Photon Mapping" is check-marked.
With "Use Photon Mapping" checked:
Everything exactly the same, except with "Use Photon Mapping" unchecked:
@Rich_Winsor - Thanks, I had inadvertently changed the material properties.  Getting back to Predefined material did the trick.
@Chrissb222 - From my limited experience, I find that on darker images Photon does make a difference, but not as much on lighter images.
    28592
    klsteffen
    klsteffen
