Quantus Posted December 5, 2017 Share Posted December 5, 2017 Hi there, Just registered and I got a little bit of pressure from someone to do this quickly so I apologize for not lurking / getting accustomed to the forum (rules) first. Not quite sure where to post this question / topic. Feel free to lay into me lol. ^__^ Anyways, trying to find a hatch file (for fill pattern on plan view) for this limestone pattern: It seems to me that it might not work because it doesn't fit nicely into a square. Thinking about just using CAD square to make it and just copy paste it / fit it together on the plan lol. Thanks in advance. Link to comment Share on other sites More sharing options...
Quantus Posted December 5, 2017 Author Share Posted December 5, 2017 Quote It seems to me that it might not work because it doesn't fit nicely into a square. Expand Nvm, I think I might have it figured out... still got to figure out how to make the file though (or find it) Link to comment Share on other sites More sharing options...
Chopsaw Posted December 5, 2017 Share Posted December 5, 2017 Take a look at this thread : Link to comment Share on other sites More sharing options...
Quantus Posted December 5, 2017 Author Share Posted December 5, 2017 Indeed, thank you. Link to comment Share on other sites More sharing options...
Kbird1 Posted December 5, 2017 Share Posted December 5, 2017 http://www.cadhatch.com/ has free hatches and seamless textures , their free Excel Hatch generator works well too , though I'm, not sure it can make that particular Hatch. M. Link to comment Share on other sites More sharing options...
Rich_Winsor Posted December 5, 2017 Share Posted December 5, 2017 If you have the time you can create the pattern using psolids with a tile material. Once you have created one instance of the pattern you can block it and copy it to create a larger area. Link to comment Share on other sites More sharing options...
rlackore Posted December 6, 2017 Share Posted December 6, 2017 Here you go: fralime.pat FYI, the pattern file I uploaded is unnecessarily long and complex (32 lines) because the simple version (12 lines), which works perfectly in AutoCAD, draws incorrectly in Chief. I've submitted this to tech support. If anyone uses AutoCAD and is interested, here is the simple version: frenchlimestone.pat Link to comment Share on other sites More sharing options...
Kbird1 Posted December 6, 2017 Share Posted December 6, 2017 Thanks Robert Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 15, 2018 Share Posted February 15, 2018 On 12/6/2017 at 2:49 PM, rlackore said: Here you go: fralime.pat FYI, the pattern file I uploaded is unnecessarily long and complex (32 lines) because the simple version (12 lines), which works perfectly in AutoCAD, draws incorrectly in Chief. I've submitted this to tech support. If anyone uses AutoCAD and is interested, here is the simple version: frenchlimestone.pat Expand It actually DOES only take 16 lines. It looks like your original pattern file was just missing 3 of them which seemed to have triggered an odd repetition problem in Chief. Here's a 16 line version of the same pattern that does work in Chief... French Limestone 2.patFetching info... 1 Link to comment Share on other sites More sharing options...
rlackore Posted February 15, 2018 Share Posted February 15, 2018 On 2/15/2018 at 5:24 AM, Alaskan_Son said: It actually DOES only take 16 lines. It looks like your original pattern file was just missing 3 of them which seemed to have triggered an odd repetition problem in Chief. Here's a 16 line version of the same pattern that does work in Chief... Expand Awesome, though it should only take 12 lines. When I submitted a tech ticket with this issue I was told that nobody at Chief understands how pattern files are written, so I guess we can't expect them to troubleshoot or fix the issue. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 15, 2018 Share Posted February 15, 2018 On 2/15/2018 at 1:30 PM, rlackore said: Awesome, though it should only take 12 lines. When I submitted a tech ticket with this issue I was told that nobody at Chief understands how pattern files are written, so I guess we can't expect them to troubleshoot or fix the issue. Expand Oops. You’re right, you said 12. I don’t know why I thought you said 16. Anyway, ya...it takes 16. At least in that particular arrangement. I guess yours must have been missing 4 then...or maybe I miscounted. Link to comment Share on other sites More sharing options...
rlackore Posted February 15, 2018 Share Posted February 15, 2018 On 2/15/2018 at 3:41 PM, Alaskan_Son said: I guess yours must have been missing 4 then...or maybe I miscounted. Expand I think the relevant point is that my 12 line pattern file isn't missing anything - it functions perfectly in AutoDesk products, and AutoDesk developed the format. I have several pattern files that work fine in AutoDesk applications but fail in Chief. Whether CA farmed out the "pattern interpreter" work, or licensed a snippet of code, I don't know - but the problem is clearly on their end. ; ; French Limestone by rlansing ; *FRALIME, French Limestone 0, 0,0, 0,48, -16,24,8 0, 0,8, 0,48, 16,-24,8 0, 0,16, 0,48, -8,32,-8 0, 0,24, 0,48, 8,-16,24 0, 0,32, 0,48, -8,24,-16 0, 0,40, 0,48, 16,-32 90, 0,0, 0,48, 8,-16,24 90, 8,0, 0,48, -8,32,-8 90, 16,0, 0,48, 16,-16,16 90, 24,0, 0,48, -16,16,-16 90, 32,0, 0,48, -24,24 90, 40,0, 0,48, 24,-24 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 15, 2018 Share Posted February 15, 2018 On 2/15/2018 at 4:05 PM, rlackore said: I think the relevant point is that my 12 line pattern file isn't missing anything - it functions perfectly in AutoDesk products, and AutoDesk developed the format. I have several pattern files that work fine in AutoDesk applications but fail in Chief. Whether CA farmed out the "pattern interpreter" work, or licensed a snippet of code, I don't know - but the problem is clearly on their end. ; ; French Limestone by rlansing ; *FRALIME, French Limestone 0, 0,0, 0,48, -16,24,8 0, 0,8, 0,48, 16,-24,8 0, 0,16, 0,48, -8,32,-8 0, 0,24, 0,48, 8,-16,24 0, 0,32, 0,48, -8,24,-16 0, 0,40, 0,48, 16,-32 90, 0,0, 0,48, 8,-16,24 90, 8,0, 0,48, -8,32,-8 90, 16,0, 0,48, 16,-16,16 90, 24,0, 0,48, -16,16,-16 90, 32,0, 0,48, -24,24 90, 40,0, 0,48, 24,-24 Expand Yeah, I was able to verify that your 12 line version works outside of Chief but I’m honestly not sure HOW it works since the repeating pattern seems to be composed of 16 line segments. I’m away from my computer now but I will have to look at the actual pattern file for mine when I get back to the office and see how it differs from yours. Link to comment Share on other sites More sharing options...
