brushpark Posted November 17, 2017 Share Posted November 17, 2017 OK, I have seen this issue on the blog before, but still can't find the fix. I want to use the room divider tool, so I could have two different ceiling heights and the divider wall removed the drywall on the connecting wall. It is possible to use this tool with two different ceiling heights? Link to comment Share on other sites More sharing options...
justmejerry Posted November 17, 2017 Share Posted November 17, 2017 You could place a door way with no casing to height you desire to replace the invisible wall. Link to comment Share on other sites More sharing options...
Kbird1 Posted November 17, 2017 Share Posted November 17, 2017 On 11/17/2017 at 8:02 PM, brushpark said: OK, I have seen this issue on the blog before, but still can't find the fix. I want to use the room divider tool, so I could have two different ceiling heights and the divider wall removed the drywall on the connecting wall. It is possible to use this tool with two different ceiling heights? Expand Yes the trick is to use a second short (12") room divider line right on the end of the Short wall , this will stop the Main Room Divider wall joining properly to the short wall so the drywall will then wrap the end of the short wall too. You will then need to add a molding polyline to the room and uncheck the "no molding on this edge" box to add the base back to the end of the Short Wall too. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted November 18, 2017 Share Posted November 18, 2017 Here's another random idea... 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted November 18, 2017 Share Posted November 18, 2017 On 11/18/2017 at 5:43 AM, Alaskan_Son said: Here's another random idea... Expand Slick. Thanks Michael. When did you come up with that idea ? Not so random. Happy 800th Link to comment Share on other sites More sharing options...
Alaskan_Son Posted November 18, 2017 Share Posted November 18, 2017 On 11/18/2017 at 6:42 AM, Chopsaw said: Slick. Thanks Michael. When did you come up with that idea ? Not so random. Happy 800th Expand Actually, just came up with that one about 5 minutes before I posted it. And thanks 1 Link to comment Share on other sites More sharing options...
mrscott Posted November 18, 2017 Share Posted November 18, 2017 All good suggestions, or should I say work-arounds to a simple issue automatically. I find it hard to believe the coders could not figure out a solution to complete the wall end. As Designers and Architects, we should not have to spend our creative time working through functional matters such as these. I would much prefer to see all of us posting beautiful examples of the work we do with a awesome program and not fixes. Image the thousands of, combined, hours we spend trying to find ways to solve common structural elements. I’m sorry but this makes no sense to me. 2 Link to comment Share on other sites More sharing options...
