bionical Posted November 17, 2017 Share Posted November 17, 2017 Just wondering if anyone knows why my live elevations and sections are so light compared to my text and linework They always seem to look greyed out. Thanks Link to comment Share on other sites More sharing options...
dshall Posted November 17, 2017 Share Posted November 17, 2017 Check your line style in your layer set. Link to comment Share on other sites More sharing options...
Chopsaw Posted November 17, 2017 Share Posted November 17, 2017 Could you explain a little more about how you got to where you are at ? You have posted a .jpg which is great as we can all see it clearly but what is it generated from ? PDF to JPG conversion, screenshot ??? Also what version of the software are you using ? It appears as you have a transparent region layered into your layout page between your dimensions and elevation view. If it is a PDF then what PDF printer are you using? Plan and layout file would also be great. Link to comment Share on other sites More sharing options...
joey_martin Posted November 18, 2017 Share Posted November 18, 2017 The line weights on you plan file do not match the line weights on your layout file. Make sure they are the same. File>Print>Drawing Sheet Setup>Advanced Line Weight Options. Make sure they are set the same on plan file and layout file. 1 Link to comment Share on other sites More sharing options...
bionical Posted November 19, 2017 Author Share Posted November 19, 2017 Thanks everyone for your ideas I checked the line weights which were the same In the end, it was Adobe PDF. When I tried the Cheif Architect Save to PDF it worked just fine Link to comment Share on other sites More sharing options...
DRAWZILLA Posted November 20, 2017 Share Posted November 20, 2017 Yes Adobe may look like that but it prints ok for me, and creates a much much smaller file and when you have a 25 page set , that makes a huge difference. Link to comment Share on other sites More sharing options...
