ShelbyVHomes Posted November 1, 2017 Share Posted November 1, 2017 Hello, I've seem to run into an issue with a current project. I have a house with one gable roof that shares a wall with the garage, which has a second gable roof. At one point on these roof planes, they intersect, and I lose my fascia on each plane, and can see inside the roofs themselves. I feel like there is some simple solution to this, but can't seem to figure it out. (Yes, this was previously posted, but I mistakenly posted via boss's account, which does no good, considering I run the program, not him! XD) Thanks! Shelby Link to comment Share on other sites More sharing options...
ShelbyVHomes Posted November 1, 2017 Author Share Posted November 1, 2017 Auto-Build gives me an extensive roof system, which I don't really need/want. So, I just drew these two manual systems, but for whatever reason, where those two planes touch, it erases my fascia on each one. I'm somewhat (>2 years) new to chief, but thought maybe it was something simple that I was over looking, or (better chance) didn't know about. Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 1, 2017 Share Posted November 1, 2017 The roof edges need to completely separate, you may need to add "Line Breaks" to separate them properly, so they do not interfere with the fascia as is currently the case. Zoom in and really carefully see how those two roof plane lines are crossing each other and then using line breaks, make sure they cleanly cross each other. For a more detailed explaination, you will need to share a copy of your plan. DJP 1 Link to comment Share on other sites More sharing options...
ShelbyVHomes Posted November 1, 2017 Author Share Posted November 1, 2017 Yes! Thanks so much David, the roof/line breaks worked perfectly! Thank you! Link to comment Share on other sites More sharing options...
ShelbyVHomes Posted November 1, 2017 Author Share Posted November 1, 2017 Well shoot. Clearly its me. I've never had much luck with the auto build feature, but I don't really use it ever, and I highly doubt I'm doing it right Link to comment Share on other sites More sharing options...
ShelbyVHomes Posted November 1, 2017 Author Share Posted November 1, 2017 I'll look into it for sure, I can see how it would save some serious time. Thanks!! Link to comment Share on other sites More sharing options...
Kbird1 Posted November 1, 2017 Share Posted November 1, 2017 I agree with Eric learning the Auto Roof basics saves alot of time and if needed you can turn auto build off and add manual roof planes... did you check out the Videos? https://www.chiefarchitect.com/videos/playlists/95/15-roofs.html Link to comment Share on other sites More sharing options...
QualicoreHomes Posted January 26, 2018 Share Posted January 26, 2018 I have a somewhat similar issue with my roof. (Not sure if it has to be in a new conversation) I have this simple garage addition with a dutch and full gable up front. I cant get the line to disappear in the fascia where it meets the upper roof (its doesn't show in regular view but I use vector views for the elevation views in my layout). Any advise? Thanks in advance Gerard Link to comment Share on other sites More sharing options...
CJSpud Posted January 26, 2018 Share Posted January 26, 2018 Yes, please start your own thread. Also, close your plan in CA, zip it and attach it for the best help. Link to comment Share on other sites More sharing options...
QualicoreHomes Posted January 26, 2018 Share Posted January 26, 2018 Thanks for your reply. I will do as soon as I'm back at the office. Thanks again! Gerard Link to comment Share on other sites More sharing options...
