Doug_N Posted October 11, 2017 Share Posted October 11, 2017 So here I am again, back at the fountain of information. A contractor is asking for flat projections of roof plans to assist his carpenters in laying out the rafters. I can see how to do elevations, and I can see how to do plan views, but is there any way to do a skewed plan from horizontal projection or section for that matter? Doug Norton Whitby Ontario 905 409 8487 Link to comment Share on other sites More sharing options...
glennw Posted October 11, 2017 Share Posted October 11, 2017 Doug, You could try File...Print...Print Model...uncheck everything except Roofs. Print to .pdf and then import the .pdf back into Chief. You should end up with something like this: 1 Link to comment Share on other sites More sharing options...
johnny Posted October 11, 2017 Share Posted October 11, 2017 Doug, I'm lost...i've never heard of the type of plan you're suggesting. If a contractor asked me to provide "flat projections" i would take that to mean basically like a truss diagram except for rafters. Something kinda like below but for every "rafter" segment just like a truss package would include. I have had framers ask for this before. I can't see how what you are describing would help them. Something like this at every rafter - depending on roof complexity - would. Link to comment Share on other sites More sharing options...
Doug_N Posted October 12, 2017 Author Share Posted October 12, 2017 Glenn, The idea here was a projection of an individual roof plane. Just imagine rotating the house so that you are perpendicular to the surface of the roof. That is what the contractor is looking for. One could then directly scale rafters along a ridge. This is a hip roof, not a gable roof. So he is looking for a rough cut list for each hip rafter. I see his point actually. Doug Link to comment Share on other sites More sharing options...
glennw Posted October 12, 2017 Share Posted October 12, 2017 You don't need a true projection to do that. Build framing and get the length of the hip through it's dbx, or the Material List. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 12, 2017 Share Posted October 12, 2017 As Glenn and Johnny already pointed out, there are several other ways to get that type of information. In addition to what they said you can also use a framing schedule or a custom macro solution. If however you still really want the skewed projection you speak of, you can do this... Turn off all layers except those that you actually want to show Convert the whole plan to a symbol Rotate the symbol onto its side using the Symbol Specification Rotation settings Create a section view for each roof plane (may require rotating the symbol more than once depending on the model) You could also optionally create separate symbols for each and very roof plane using layer settings, the Delete Surface tool, or by copying and pasting each individual plane to a blank plan. You can then do the same thing I went over above...Rotate the symbol and then just use a section view. Link to comment Share on other sites More sharing options...
raltd9245 Posted October 14, 2017 Share Posted October 14, 2017 Experience and a roofing square should do the job. 1 Link to comment Share on other sites More sharing options...
