Arcadian Posted May 17, 2017 Share Posted May 17, 2017 Hi All ! have an interesting hardware issue. My main desktop is in for repair so am using my SP4 as backup. Have connected my Samsung 4K monitor to my SP and all working well. Open Chief and display on monitor. Still good so far. When I open a plan file to work on the cursor has a lag behind the mouse movement when working over the plan file. Same on layout file. Yet, when I open Chief and plan or layout file on the SP.. no problem. All other programs opened on the monitor are fine and don't have this issue. Only Chief. My apologies for waffling on, but it's a bit frustrating. Any thoughts? Link to comment Share on other sites More sharing options...
DavidJPotter Posted May 17, 2017 Share Posted May 17, 2017 You can always communicate with Tech Support on such matters, they handle this sort of thing on a daily basis. If it happened to me, I would first suspect my mouse drivers and make sure they are fully up to date. See if that helps. There are several things one can do and check for but I would start there and see if that helps or betters your performance. BTW what is a "SP4"? DJP 1 Link to comment Share on other sites More sharing options...
Arcadian Posted May 17, 2017 Author Share Posted May 17, 2017 Thanks David, will check the driver to start then get hold of Tech Support. SP4 - Microsoft Surface Pro 4 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted May 19, 2017 Share Posted May 19, 2017 I remember back a ways, the crosshairs on would slow down things a bit, turn them off and see. Since you didn't say what version you are using, I have no way of knowing. Link to comment Share on other sites More sharing options...
Arcadian Posted May 19, 2017 Author Share Posted May 19, 2017 Morning Perry,(in NZ anyway) Using X9. Will try that later. Thanks Link to comment Share on other sites More sharing options...
glennw Posted May 20, 2017 Share Posted May 20, 2017 It's not clear from your post whether there is a lag between your cursor and cross hair or you are trying to describe some other behavior. Have you tried playing with the Synchronize with Cursor toggle? Link to comment Share on other sites More sharing options...
Arcadian Posted May 20, 2017 Author Share Posted May 20, 2017 Hi Glenn, Thanks for the response. Ha ! didn't even know there was one ! Will find it and try. Andy Smith Link to comment Share on other sites More sharing options...
DRAWZILLA Posted May 20, 2017 Share Posted May 20, 2017 it's in the Preference's / edit section. Link to comment Share on other sites More sharing options...
D-Lewis Posted October 30, 2017 Share Posted October 30, 2017 Hi Andy, I had the same issue with my SP4. Did you manage to get it sorted? Link to comment Share on other sites More sharing options...
StudConstruction Posted February 7, 2018 Share Posted February 7, 2018 Hey All, For me, my issue was resolved by: Edit > Preferences > Edit > uncheck "Synchronize with Cursor" Hope that helps others! and thanks to @glennw for the tip! Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 7, 2018 Share Posted February 7, 2018 22 minutes ago, StudConstruction said: Hey All, For me, my issue was resolved by: Edit > Preferences > Edit > uncheck "Synchronize with Cursor" Hope that helps others! and thanks to @glennw for the tip! That one is an oldie but goodie, surprised it's still around after Chief has fixed it many time before Link to comment Share on other sites More sharing options...
StudConstruction Posted February 7, 2018 Share Posted February 7, 2018 Just now, DRAWZILLA said: That one is an oldie but goodie, surprised it's still around after Chief has fixed it many time before Out of curiosity are there any downsides to unchecking this? Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 7, 2018 Share Posted February 7, 2018 2 minutes ago, StudConstruction said: Out of curiosity are there any downsides to unchecking this? I used to have that unchecked when Chief had problems without any undesired effects. I'm using X10 now and have it checked without any problems, come to think about X9 it was also checked without problems. Check you mouse drivers to see they are up to date Link to comment Share on other sites More sharing options...
