timmy123 Posted June 22, 2014 Share Posted June 22, 2014 Hi, I want to put a railing on my driveway but it is not forming at the level of my driveway. It is at the level of my second floor which is higher than the driveway by a foot or so. Please check attached images. Thanks Link to comment Share on other sites More sharing options...
Kiwideziner Posted June 22, 2014 Share Posted June 22, 2014 I think there is an option to tick follow terrain or something like that. not got access to CA at the moment. Link to comment Share on other sites More sharing options...
glennw Posted June 23, 2014 Share Posted June 23, 2014 Is your driveway made from a floor, part of the terrain, an object.... If follow terrain doesn't work, try Wall Specification...Rail Style panel...Build From...Generate on Low Platform. Otherwise...post the plan. Link to comment Share on other sites More sharing options...
tommy1 Posted June 23, 2014 Share Posted June 23, 2014 If you want a quick fix, do this. Select your railing wall. Open it. Uncheck "railing" in the wall DBX.. Take an elevation view. Now you can drag the bottom of the wall down. Once you have it down to where you want it, click OK. Now select the wall again and re-check "Railing". Hit ok. Done. If you move the wall again, it may jump again and then you'll have to go through the steps again. All this can be done in less than a minute. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 23, 2014 Share Posted June 23, 2014 Or make a symbol and place it where you want. Link to comment Share on other sites More sharing options...
