Rich_Winsor Posted February 20, 2017 Share Posted February 20, 2017 Is anybody else experiencing this in X9? >Draw a simple floor plan. >Build the roof and framing. >Take a Perspective Framing Overview. >Run a quick Ray Trace with default settings. The wall framing will not display in the Ray Trace. I just performed the exact same operations in X8 and everything displays just fine in the Ray Trace. Link to comment Share on other sites More sharing options...
Chopsaw Posted February 20, 2017 Share Posted February 20, 2017 Never tried ray tracing wall framing before but I think you have made a discovery here Rich. Good work. Good thing I notched those psolid corner posts. They are holding up the whole building. Link to comment Share on other sites More sharing options...
Chopsaw Posted February 20, 2017 Share Posted February 20, 2017 Rich are you sending ray traces to layout because of this problem. Plot lines with no color fill shows up as only shadows for me. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted February 20, 2017 Share Posted February 20, 2017 Chopsaw, kind a' nice art form though. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 20, 2017 Share Posted February 20, 2017 Interesting, I wonder if CA decided to ignore the Wall Framing in order to speed up the Ray Trace. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 20, 2017 Share Posted February 20, 2017 It all seems to be working just fine for me... Ray Trace Plot Lines Chopsaw, is it possible you have your framing layers set to be using either white or the invisible line style in that particular layer set? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 20, 2017 Share Posted February 20, 2017 Ditto - I just tried it and the wall framing is showing in the RT. Something is different between what Michael and I are doing - vs what Rich and Chopsaw are doing. Link to comment Share on other sites More sharing options...
Chopsaw Posted February 20, 2017 Share Posted February 20, 2017 3 hours ago, Alaskan_Son said: Chopsaw, is it possible you have your framing layers set to be using either white or the invisible line style in that particular layer set? Michael, Solid Black line style, line weight 25, 3D Framing Set. This raytrace problem may be related to the size of the structure as I am not sure that Michaels shed compares to what Rich and I are doing. I just raytrace a 100 sq. ft. shed's stud framing without issue and also not that it is directly related I was able to send smaller images to layout in the tech ill style as plot lines without issue. If Rich and I are getting the same results then it cant be the classic NVIDEA vs. AMD issue although it could be a 2 GB limitation but I don't see that as valid issue here because Rich does great ray tracing all the time. Could someone pull out a file that is a little larger and more complete framing system and give it a raytrace in standard view? Link to comment Share on other sites More sharing options...
Chopsaw Posted February 20, 2017 Share Posted February 20, 2017 Rich, Brian is aware of the issue and it seems that you need to have "Framing, Wall " turned on in the layer that you generate the camera view from. Also may not work with 2 3D views open unless they are both displaying framing. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 20, 2017 Share Posted February 20, 2017 There's definitely some funny things going on with framing layers in general. I haven't had the spare time or energy to write up anything useful for tech-support yet but I have wall framing turning itself on all the time in layer sets that I'm not even working in. It seems to be triggered by opening a wall or truss detail Link to comment Share on other sites More sharing options...
