Dennis_Gavin Posted January 31, 2017 Share Posted January 31, 2017 anyone having trouble with mirror reflections in X9? Check out vanity mirror. Spiller_basement_2.plan Link to comment Share on other sites More sharing options...
dshall Posted January 31, 2017 Share Posted January 31, 2017 No problems here..... I think it depends on what camera you are using, Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted January 31, 2017 Author Share Posted January 31, 2017 hmmmm, I am not getting any reflection. X8 works fine, Link to comment Share on other sites More sharing options...
Dermot Posted January 31, 2017 Share Posted January 31, 2017 Your picture does not show that you have actually have the reflections turned on in your active camera. It shows that you have the reflections on in your Camera Defaults. Use the Edit Active Camera tool to open the Full Camera Specification dialog box and then verify that you have Reflections turned on. If your camera has reflections turned on but they still don't show, then my best guess is that you are having a problem with your video card or that you have messed up your render preferences somehow. If you still can't solve your problem, I would recommend that you contact tech support. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted January 31, 2017 Author Share Posted January 31, 2017 Why does it work in X8 but not X9? Video card is same for both, Nvidia. Never had this problem before. Active camers has reflections on. Link to comment Share on other sites More sharing options...
javatom Posted January 31, 2017 Share Posted January 31, 2017 I did not load plan, but could it be the mirror material. It may have something not quite right. Try placing a new mirror. Link to comment Share on other sites More sharing options...
dshall Posted January 31, 2017 Share Posted January 31, 2017 18 minutes ago, Dennis_Gavin said: Why does it work in X8 but not X9? Video card is same for both, Nvidia. Never had this problem before. Active camers has reflections on. Did you open plan in x8 and did you see reflection? Did you then save plan and then open in X9 and not see reflection? BTW, open your mirror and change thickness to 11", all okay, now change to 12" thickness..... mirror quality disappears, not earth shattering, but a quirk. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted January 31, 2017 Author Share Posted January 31, 2017 Why does it work in X8 but not X9? Video card is same for both, Nvidia. Never had this problem before. Active camers has reflections on. Did try another material Link to comment Share on other sites More sharing options...
javatom Posted January 31, 2017 Share Posted January 31, 2017 I just loaded it up in x9 and it looks reflective on my system. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted January 31, 2017 Author Share Posted January 31, 2017 Scott - opened in X8,,,fine. Closed opened in X9, camera reflections not on in camera default or active camera. Turned it on in both and no change. Saved X9 plan, closed chief, re-opened and took camera shot and still no reflection Link to comment Share on other sites More sharing options...
javatom Posted January 31, 2017 Share Posted January 31, 2017 Open a different plan (one with a mirror in it). This might help determine if you have a plan problem or a system problem. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted January 31, 2017 Author Share Posted January 31, 2017 same in other plan. Submitted to tech support. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted January 31, 2017 Share Posted January 31, 2017 Maybe the mirror material is different in X9 than X8. I know when Chief started the new reflection tool I couldn't use the old mirror material. You might be using an old material, try to choose a mirror material from the lib. BTW, your plan reflects good in X9 for me Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted January 31, 2017 Author Share Posted January 31, 2017 Did try that Perry, no luck. ;o( Link to comment Share on other sites More sharing options...
Dermot Posted January 31, 2017 Share Posted January 31, 2017 Quote If your camera has reflections turned on but they still don't show, then my best guess is that you are having a problem with your video card or that you have messed up your render preferences somehow. Is it possible that you turned off "Use Enhanced Lighting" in your X9 preferences? You will not get reflections if you have turned this off. The only reason to turn this off is if you are trying to troubleshoot video card problems but you should not leave it off. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted January 31, 2017 Author Share Posted January 31, 2017 BINGO! You the man Dermot. I was really going nuts with this.......not a far trip! ;o) Thank You! Link to comment Share on other sites More sharing options...
DRAWZILLA Posted January 31, 2017 Share Posted January 31, 2017 Nice Dermot, but who would have thought the Use Enhanced lighting was in anyway connected to the reflections. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted January 31, 2017 Author Share Posted January 31, 2017 Not me! Link to comment Share on other sites More sharing options...
