olyconstruction Posted January 4, 2017 Share Posted January 4, 2017 Hi Chiefs, I have this fence in my plan and it is doing this awful thing where it is extending the balusters way up above the top rail. I have it set to "follow terrain". When I set it to stepped terrain it acts even weirder, elevating all the balusters about 5' above the post & rail. Does anyone know what is making this happen and what kind of settings I need to adjust to make it look normal? Tried looking online but there does not seem to be that much on fences. Thanks! Link to comment Share on other sites More sharing options...
javatom Posted January 4, 2017 Share Posted January 4, 2017 Check the definition on your rail wall. Set the specs so it functions as a rail and not a wall. (Assuming you used a wall for the fence) Link to comment Share on other sites More sharing options...
olyconstruction Posted January 4, 2017 Author Share Posted January 4, 2017 Thanks Javatom but I did have it set as a railing. I used the railing tool to begin with. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 4, 2017 Share Posted January 4, 2017 Post the Plan - Please !!!! Link to comment Share on other sites More sharing options...
javatom Posted January 4, 2017 Share Posted January 4, 2017 Maybe you need to check that the wall is "no locate". It may be trying to define a room. Link to comment Share on other sites More sharing options...
Kenoeightspot Posted January 4, 2017 Share Posted January 4, 2017 I can come close to what you have. If you do not want to send the plan then send images from the DBX. Link to comment Share on other sites More sharing options...
olyconstruction Posted January 4, 2017 Author Share Posted January 4, 2017 Sorry I was lunching. Here is the plan, while you have it open please let me know if any of you know why I might be having trouble with retaining walls. I keep trying to create them the way the training video shows, but nothing seems to happen. I wonder if it is not a related problem to the fence. Thank you very very much! MORGAN_AS_BUILT_SITE.zip Link to comment Share on other sites More sharing options...
Kenoeightspot Posted January 4, 2017 Share Posted January 4, 2017 Delete then place new fence MORGAN AS BUILT SITE-REBUILD FENCE.zip Link to comment Share on other sites More sharing options...
olyconstruction Posted January 4, 2017 Author Share Posted January 4, 2017 I tried that but I am getting the same thing. The height seems to be related to the slope of the terrain. Link to comment Share on other sites More sharing options...
Kenoeightspot Posted January 4, 2017 Share Posted January 4, 2017 Did you use the plan I sent back. Link to comment Share on other sites More sharing options...
olyconstruction Posted January 4, 2017 Author Share Posted January 4, 2017 No, I did not see it attatched WP Link to comment Share on other sites More sharing options...
Kenoeightspot Posted January 4, 2017 Share Posted January 4, 2017 Something else is going on with the "Terrain". When I place a fence in 3d it will work but when I place a fence in plan view I get the same results as you. ????? Link to comment Share on other sites More sharing options...
olyconstruction Posted January 4, 2017 Author Share Posted January 4, 2017 Wow, well when I try in 3D it is still messed up. I wonder what it could be Link to comment Share on other sites More sharing options...
javatom Posted January 4, 2017 Share Posted January 4, 2017 Your terrain is on level 0. I usually place it on level 1. Link to comment Share on other sites More sharing options...
Kenoeightspot Posted January 4, 2017 Share Posted January 4, 2017 Place terrain on level 1 seems to fix it. Link to comment Share on other sites More sharing options...
glennw Posted January 4, 2017 Share Posted January 4, 2017 52 minutes ago, olyconstruction said: Wow, well when I try in 3D it is still messed up. I wonder what it could be You are probably drawing them on different floors. The floor you are drawing on in 3D is the current floor. Javatom just beat me to it - you have everything drawn on level 0. I would insert a floor beneath the current level 0. Then select the fences and check Generate on Low Platform, but I think that is probably just a workaround. Redraw the fences on your new level 1 and you don't need to check Generate On Low Platform.. Link to comment Share on other sites More sharing options...
olyconstruction Posted January 5, 2017 Author Share Posted January 5, 2017 Glenn, it looks like if I just check the generate on lower platform it fixes my problem. Thankfully this is just my site model, when I added the new level it changed the reference level for alot of my geometry and the foundation rooms. I will be careful in the future to create my terrain on level 1, although it seems counter intuitive to me, shouldnt the landscape and the grade be associated with the foundation? Its just the way I think about it I suppose. Anyway thanks for the help, glad we got to the bottom of it! Link to comment Share on other sites More sharing options...
