cheif3013 Posted January 3, 2017 Share Posted January 3, 2017 I am trying to make a 'T' shaped stair case, however the walk through provided works fine for the type of stair case demonstrated. My "T" stair case has two lower legs leading to a landing with 1 upper leg leading to the second floor. When I make the 1 lower, 1 upper and then run the landing tool it creates the stairs as expected with landing. When I adding the second lower leg it creates a multisided staircase (despite there being walls in the way) - see "Capture2.png". If I shrink the width of the stair case it will draw correctly but complains that they do not have matching width - see "Capture1.png" What am I missing? Link to comment Share on other sites More sharing options...
glennw Posted January 3, 2017 Share Posted January 3, 2017 Uncheck "Allow Rap" (at the bottom of the Style panel). Link to comment Share on other sites More sharing options...
BrownTiger Posted January 3, 2017 Share Posted January 3, 2017 Like Glen said, Chief Architect does automatically wrap around stairs, you need to uncheck "allow wrap", this setting is more for an exterior deck. Link to comment Share on other sites More sharing options...
cheif3013 Posted January 5, 2017 Author Share Posted January 5, 2017 I see references to the "Allow Wrap" checkbox in the documentation, however I do not have that as an option on my Style menu Link to comment Share on other sites More sharing options...
Chopsaw Posted January 5, 2017 Share Posted January 5, 2017 Looks like there are a lot of things missing from your DBX and your chief icon is Purple. What version are you running? Link to comment Share on other sites More sharing options...
glennw Posted January 5, 2017 Share Posted January 5, 2017 Try using a Box, Polysolid, slab, etc, instead of the Landing Link to comment Share on other sites More sharing options...
BrownTiger Posted January 5, 2017 Share Posted January 5, 2017 Purples icons are for ChiefArchitect Interiors. Link to comment Share on other sites More sharing options...
cheif3013 Posted January 6, 2017 Author Share Posted January 6, 2017 I am running Interiors - the link referenced here shows it applies to Interiors. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 6, 2017 Share Posted January 6, 2017 Without seeing the plan, it's hard to tell fro sure, but if you can't get it figured out otherwise, try changing the overall height of one of the stair sections by maybe just 1/16" so that the 2 sections are no longer identical. They have to be identical in order to automatically wrap. Link to comment Share on other sites More sharing options...
cheif3013 Posted January 6, 2017 Author Share Posted January 6, 2017 On the landing I unchecked "Auto Adjust Height When Connected To Stairs" and the issue went away. Thanks for the suggestions Link to comment Share on other sites More sharing options...
Dermot Posted January 6, 2017 Share Posted January 6, 2017 You are using Home Designer Interiors. HD Interiors does not allow you to control the stair wrapping directly. Turning off auto height appears to give you a reasonable work-around though. The video you linked to only applies to Chief Architect Premier or Chief Architect Interiors. You will probably get better help using the Home Designer web site and forum: https://www.homedesignersoftware.com/ https://hometalk.chiefarchitect.com/ 1 Link to comment Share on other sites More sharing options...
