Have plumbing appear on slab foundation
Korel_Design
Place a toilet fixture in blank plan and make cad detail from view. remove most of the lines. Change lines to gray dashed. select and block then add to your lib. for your future use.
On foundation level turn on reference set. Place toilet cad block from lib. and center over the toilet in the reference set. Turn off reference set and add dim.
OR
Just use the reference set
1 hour ago, dshall said:
.....  and why not?
Because the location of some of the fixtures do not show up and I need to precisely bulls eye the plumbing penetrations on the slab. It cost a lot of money to move a toilet over a few inches. The floor reference doesn't do that. I will look into William's suggestion.
Thanks,
JK
I use reference sets.
Facing the toilet the dim. tool will find the center left or right. The other direction the dim. tool will not find the rough in point, you will have to dim. that by hand, typ.12.5" from framing or whatever the manufacturer specifies. Let your plumber be responsible for that dimension.
