buzzsaw204 Posted November 1, 2016 Share Posted November 1, 2016 hi, is there a toggle to change the Door Swing before you insert the door. When I first initiate to Insert a door, my door swing is always on the left. I would have to insert the door, and take an extra step to Flip the door. Is there a way to toggle the door to the right, then initiate the insert. thanks, Link to comment Share on other sites More sharing options...
Solution kMoquin Posted November 1, 2016 Solution Share Posted November 1, 2016 If you click and hold when placing the door, you can move the mouse around to various different door orientations. Let go of the mouse button when the door in in the orientation you want. 2 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 1, 2016 Share Posted November 1, 2016 Like Richard said, the key is to hold down the left mouse button while moving the mouse. 1 Link to comment Share on other sites More sharing options...
JJohnson Posted November 1, 2016 Share Posted November 1, 2016 I appreciate the question, and the answers ! These little tips are so helpful. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted November 1, 2016 Share Posted November 1, 2016 Or just click on the edit toolbar to switch the open side. Link to comment Share on other sites More sharing options...
Kduke11 Posted November 1, 2016 Share Posted November 1, 2016 If you click and hold when placing the door, you can move the mouse around to various different door orientations. Let go of the mouse button when the door in in the orientation you want. Thanks!! Link to comment Share on other sites More sharing options...
