DBearss Posted October 21, 2016 Share Posted October 21, 2016 Its common here in the northwest to have perimeter stem walls with a slab on grade and interior thickened slab or monolithic footings. Top of slab flush with top of stem wall. I can get the perimeter walls to work like I want but am struggling with the interior thickened slab. Even if I change defaults and draw manually I cannot get the interior wall to be a thickened slab or monolithic. I searched for a discussion but found none. I also tried building foundation as monolithic slab and then tried deleting the perimeter and creating manually but when changing the default the mono footing also change. Is there any way to have two types of footings in the same plan? Link to comment Share on other sites More sharing options...
olyconstruction Posted October 21, 2016 Share Posted October 21, 2016 Hi David, I would suggest building a "slab with footing" under the interior walls you want, if I am understanding your issue correctly. You can specify the dimensions of the footing in the slabs object DB, it is one of the options under the slab tool. If that does not work, you may be able to fiddle with your wall types, that is change them to a foundation wall to give it a footing, then change it to a pony wall in the wall types section, giving it a concrete stem wall on the bottom and a regular inteior wall on top, then mess with the room structure to get the slab where you want it. I hope this helps, good luck! AB Link to comment Share on other sites More sharing options...
dshall Posted October 21, 2016 Share Posted October 21, 2016 Its common here in the northwest to have perimeter stem walls with a slab on grade and interior thickened slab or monolithic footings. Top of slab flush with top of stem wall. I can get the perimeter walls to work like I want but am struggling with the interior thickened slab. Even if I change defaults and draw manually I cannot get the interior wall to be a thickened slab or monolithic. I searched for a discussion but found none. I also tried building foundation as monolithic slab and then tried deleting the perimeter and creating manually but when changing the default the mono footing also change. Is there any way to have two types of footings in the same plan? If you have time to post a plan and a picture clearly stating what you want, I will have the time to do a vid to show you how to get what you want. Link to comment Share on other sites More sharing options...
DBearss Posted October 21, 2016 Author Share Posted October 21, 2016 Here is the typical interior footing. see picture. I will post plan as well. Thanks. Link to comment Share on other sites More sharing options...
DBearss Posted October 21, 2016 Author Share Posted October 21, 2016 and the plan Bishop Blum.plan Link to comment Share on other sites More sharing options...
DBearss Posted October 21, 2016 Author Share Posted October 21, 2016 Alex, The slab with footing is a simple workaround. Had not explored the slab tool much. Thanks. Link to comment Share on other sites More sharing options...
GeneDavis Posted October 21, 2016 Share Posted October 21, 2016 I can get the right (almost) amount of concrete under the floor slab under the wall, but am unable to do the floor slab and the wall footing as a monopour. Furthermore I cannot get the sides to chamfer. Did I understand this right? A stemwall on footing is done around the perimeter, and a slab on grade is poured after so top is flush to top of stemwall? Link to comment Share on other sites More sharing options...
DBearss Posted October 21, 2016 Author Share Posted October 21, 2016 Gene, You are correct. Our energy code required that the slab edge be isolated from the exterior wall. Otherwise the slab edge would have to be insulated on the exterior. TYPICAL WALL - INSULATED SLSLAB EDGE.pdf Link to comment Share on other sites More sharing options...
Kenoeightspot Posted October 21, 2016 Share Posted October 21, 2016 Something like this: I use the pyramid shape truncated and rotated 180. Link to comment Share on other sites More sharing options...
GeneDavis Posted October 21, 2016 Share Posted October 21, 2016 Yes, I struggled with that on a plan that required a bearing wall down the center of a full depth basement. The basement floor slab is a separate pour after the footings and stemwalls are poured, and it sits atop the footings. I could do the wall with its under-footing, but only as I showed in the pic attached above. When I tried to call the footing a monopour, it changed the entire scheme to show the footings for walls all done as one pour, slab included. It is not how it's built, and I could not use the sections at all. So you can sort of get what you need, but your building section won't look true. You'll need to CAD-correct things. Link to comment Share on other sites More sharing options...
GeneDavis Posted October 21, 2016 Share Posted October 21, 2016 That's a nice workaround, Scott. For my straight end to end footing, I would use a p-line solid. One still needs to white-out the section view to make it look like footing and slab are poured together. Link to comment Share on other sites More sharing options...
ACADuser Posted October 25, 2016 Share Posted October 25, 2016 Look here for more discussion. https://chieftalk.chiefarchitect.com/index.php?/topic/3300-interior-foundation/?hl=%2Bthickened+%2Bslab Link to comment Share on other sites More sharing options...
