djhplanning Posted September 3, 2016 Share Posted September 3, 2016 Trying to figure out a problem. I'm setting up interior cabinet elevations using the wall elevation view tool. I have a special layer set called "cabinet interior elevations", which I have set up the way I want my interior elevations to look. No problem getting views on my main level (floor 1). I now move down to my lower level (floor 0) and I am getting blank screens when using wall elevation tool. It looks like the information is there because it will show up when I use the "all on set" layer set. What is going on here???? Link to comment Share on other sites More sharing options...
Chopsaw Posted September 3, 2016 Share Posted September 3, 2016 Select a dimension when they are visible in the all on layer set and with your Active layer Display Options open it will highlight which layer it is being placed on. Then you can track it down and see if your defaults are set correctly. Not sure why level 0 would behave different than level 1, maybe a good one for tech. Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 3, 2016 Share Posted September 3, 2016 What you describe is weird (I have never seen this myself, ever) so my advice is to contact Tech Support for help finding out what you are doing wrong or ineffectively. Rather than merely calling Tech Support you might submit a copy of your plan along with your complaint report so they have all the data. DJP Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 3, 2016 Share Posted September 3, 2016 Post the plan and see if we have the same problem Link to comment Share on other sites More sharing options...
Solution Alaskan_Son Posted September 5, 2016 Solution Share Posted September 5, 2016 Dan, Make sure your Foundation layer is turned on. It controls the display of anything and everything on floor zero.Hope that helps. Link to comment Share on other sites More sharing options...
