Fortress Posted August 30, 2016 Share Posted August 30, 2016 How do I create stadium type seating for a movie theater Thanks in advance Link to comment Share on other sites More sharing options...
HamlinBC Posted August 30, 2016 Share Posted August 30, 2016 Either multiple rooms defined with invisible walls, or polyline solid. Link to comment Share on other sites More sharing options...
Gawdzira Posted August 30, 2016 Share Posted August 30, 2016 Stair landings? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 30, 2016 Share Posted August 30, 2016 or just very wide stairs ? Of course, when you place the seating you will have to manually set the height from the floor so they are on top of the treads. Link to comment Share on other sites More sharing options...
Chopsaw Posted August 30, 2016 Share Posted August 30, 2016 I Don't see any steps in your thumbnail. If you are going to allow wheelchair access you may want to check out this thread:https://chieftalk.chiefarchitect.com/index.php?/topic/9864-sloped-floor/ Link to comment Share on other sites More sharing options...
johnny Posted August 30, 2016 Share Posted August 30, 2016 Either multiple rooms defined with invisible walls I personally would try this method first, since there are some interesting advantages (moldings, better framing details, etc) if you can make that work. You could even use curved walls to give the edges a radius (if your seating allowed). Link to comment Share on other sites More sharing options...
pintodesign Posted August 30, 2016 Share Posted August 30, 2016 I just did this for a movie theater. I set the bottom height and the top height and used poly solids for the intermediate steps. You need to look at the viewing angle, screen size, center focus, etc....there are many things to take into consideration. Good luck... Barb theater section.pdf Link to comment Share on other sites More sharing options...
