buzzsaw204
How to Rotate an object by degree...
hi,
i havent grasp the method on how to Rotate an object by manually entering the Degree.
i know that Line is currently 67..Degree... by drwing a line that Perpen. to it and listing the property of it.
i want to rotate my Property line, that my left Lot line to be 90 degree.
my logic is....
the Red line is 67Degree....and if i want to it to be 90degree (12oclojck). i would rotate it -23 degree (counnter c/w)??
some how, i dont think CA uses this logic in rotating an object.
can someone shed a light on this....
thanks,
Draw a line at the angle you want
Draw a line at the same angle as the object
With the angle tool measure the angle between the two lines
Select the line that is at the same angle as the object and select the object
Open the angled measurement and enter "0"
This will align the object to the required line angle
Or use the transform- replicate tool to do it.
Buzzsaw,  You have it all figured out but you need to use CA logic.   +23o  is ccw.
Here's a quick video I made for Johnny a while back. You might find a useful tidbit in there. Also, in addition to the tools mentioned above and the tools in the video, bear in mind that Make Parallel/Perpendicular and Point To Point Move are your friend when it comes to rotating things. Have a good day everyone.
P.S. Nice illustration Chop!
https://m.youtube.com/watch?v=3dxj-Ec-pgY
    27485
    ricatic
    ricatic
