Designer100 Posted August 2, 2016 Share Posted August 2, 2016 Where can I get a Microwave Hood vent for 36in electrical range? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 2, 2016 Share Posted August 2, 2016 AFAIK there's no such appliance. I'm not talking about a symbol - that could be done but I don't know of any appliance manufacturer that makes a 36" over the range microwave. 30" is the max. 2 Link to comment Share on other sites More sharing options...
MarkMc Posted August 2, 2016 Share Posted August 2, 2016 GE has a filler kit for some of it's OTR microwaves-maybe some others do as well. http://products.geappliances.com/appliance/gea-specs/PVM9179SKSS I've never used it and never will- none have sufficient CFM for a 36" range. Link to comment Share on other sites More sharing options...
joey_martin Posted August 2, 2016 Share Posted August 2, 2016 I have not seen that size either. Best bet is to use a 30" w/ 3" decorative fillers on each side. Be careful not to use the pull-out fillers though...they dont have sides and don't work well next to an upper microwave. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 2, 2016 Share Posted August 2, 2016 I say this with a lot of personal and professional experience and expertise on the matter... I would strongly recommend against using a 30" microhood over a 36" range even with the special trim kit or decorative fillers. Those microwaves are typically terrible exhaust appliances as it is and your range hood should really be at least as wide as the appliance it is serving (ideally it should be even wider). So...you would then be using one of the cheapest and lowest quality exhaust fans you could buy and then undersizing it. Link to comment Share on other sites More sharing options...
Greg_NY61 Posted August 2, 2016 Share Posted August 2, 2016 They started to make 36" microwaves now, Maytag is one of them 36" 1.9 Cu Ft Over the Range Microwave Model # UMV2186AAW 1 Link to comment Share on other sites More sharing options...
Designer100 Posted January 4, 2017 Author Share Posted January 4, 2017 Thanks for imput Link to comment Share on other sites More sharing options...
Greg_NY61 Posted January 4, 2017 Share Posted January 4, 2017 GE Monogram Model #ZV850SB 36" you can find it on 3D warehouse, there are many more 36" models there like 36" Pro-Style Low Profile by Whirlpool which is getting very popular around here, Model #JXU9136WP. Link to comment Share on other sites More sharing options...
RobUSMC Posted January 4, 2017 Share Posted January 4, 2017 For fire safety and hood should extend 3" past the edge of the cooking surface so there will not be combustible materials (fillers) over the heat source. For a 36" cooktop (especially gas) we will install a 42" hood. 39" at a bare minimum. However with a MW your catch 22 Link to comment Share on other sites More sharing options...
