Nvidia GTX 580
micro181
Go to solution Solved by micro181,
did you just change cards ? , if you didn't clean the AMD drivers out of the computer properly before installing the GTX580 there may  be a driver conflict happening , I have seen this issue before when swapping cards.
Try a program like Driver Sweeper , and reinstall the latest Nvidia drivers
http://www.guru3d.com/content_page/guru3d_driver_sweeper.html
edit actually this is their newer program now
http://www.guru3d.com/files_details/display_driver_uninstaller_download.html
There is a thread on NVidia settings I asked about a few months ago to help with CA and its speed....worth a try.... I actually downgraded my Nvidia drivers to an older version for better speed too.... ie latest my not be fastest esp. for older Hardware like my GTX 470
https://chieftalk.chiefarchitect.com/index.php?/topic/321-nvidia-driver-settings/?hl=%2Bnvidia+%2Bdrivers
Make sure the video defaults are correct in X1 Render Preferences setup. Since its working in all the other programs it should be working in X1. Swap the settings on items like hardware acceleration...don't remember X1 Preferences.
That's true Perry ...Shadows are a killer for quick 3d views ,I rarely use them as I still have the GTX 470 and mostly use Vector view , to check out how things are going. The 580 is older but it isn't X6 he is trying to run ,it should kill in X1 no problem ,he hasn't mentioned the OS he is using X1 with , that maybe part of the issue too.
Hi, when I checked the preferences and then render it says the following:
openGLdriver status Intel
OpenGLvender Intel
OpenGL Renderer Intel® HD graphics 3000
It doesn't say anything about my Nvidia GTX 580
Could this be the problem?
If so, does anyone know how I can change it
Another thought I had was the following:
I used driver sweeper to removed all aspects of the AMD and then reloaded the Nvidia - Same problems existed. Should I have also re-loaded CA X1
let me know your thoughts ...
OpenGLvender Intel
You have to change to the NVidia card in the NVidia control panel, change it there. You are still running the intel built in card.
Oh... it is a laptop by the looks......posting ALL pertinent info does help :)
switching to the 580 should do it , though unsure why other titles are running smoother unless they automatically use the 580.
I changed back to Nvidia 314.09 Drivers from the latest which cured other problems I had...
once you reset the card /drivers check that the 3d setting Perry posted in the other Thread are active/still setup for CA X1
I tried that, but it still doesn't change anything - It works OK in Home Designer 2014 (when you go to the 3D part and move the house it's smooth, but not in the X1)
In home designer it also says the same for the driver of intel 3000, so maybe there is another setting somewhere that needs to be changed?
Up until a couple months ago I used the GTX 580 w/ no problems or slowdowns. I wanted more video outputs & upgraded to the 770Classified card; but the 580 ran X6 very well: I put the card in my wife's PC. Once you get the driver's straightened out, you should be happy w/ this card.
  On 5/29/2014 at 7:30 AM, micro181 said:
I can't see where to make the edges zero in X1 - Can you let me know where to do it - I did check in preferences but it's not there?
See my post on post #22.
