SNestor Posted May 4, 2016 Share Posted May 4, 2016 Can someone tell me why the drywall on the end of the short wall disappears when I connect the wall to an "invisible" wall? I've created the same space using one CA stock template plans...and the drywall stays in place. So...maybe it's a preference of a wall definition...or something I've done. I've attached the plan and a couple of pics... Ranch Plan 050116.planFetching info... Link to comment Share on other sites More sharing options...
SNestor Posted May 4, 2016 Author Share Posted May 4, 2016 Another question regarding the same plan as attached in the OP. This has to do with "roof returns". I've created manual roof returns on the front of the garage. The garage roof is 12/12. The roof returns are 8/12. When I pull the roof return up so that the roof abuts the gable end wall...I get a frieze board...but I lose the closed boxed end. If I pull the roof away from the gable end I get the boxed end...but lose the frieze. Am I doing something wrong...or is this a quirk in CA? Or...is there a better way to accomplish this? Thanks again... Link to comment Share on other sites More sharing options...
Chopsaw Posted May 4, 2016 Share Posted May 4, 2016 I recently tried to get rid of a end wall finish and tried the invisible wall connection trick without any success. Here is another post that I read at the time that might help. https://chieftalk.chiefarchitect.com/index.php?/topic/7199-issue-with-suppressing-casing-and-sheetrock-wrapping-nub-walls/?hl=%2Bwall+%2Bwrap What I did to show the framing was to frame the wall and then shorten it to expose the studs. Maybe try the opposite. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 4, 2016 Share Posted May 4, 2016 On 5/4/2016 at 5:47 PM, SNestor said: Can someone tell me why the drywall on the end of the short wall disappears when I connect the wall to an "invisible" wall? I've created the same space using one CA stock template plans...and the drywall stays in place. So...maybe it's a preference of a wall definition...or something I've done. I've attached the plan and a couple of pics... I believe the source of your problem is that dropped ceiling and the corresponding top section of wall that is automatically created (thereby changing the way that invisible wall works). I just don't think the invisible wall method works very well in that situation. I would use a Doorway. Just suppress the casing and Edit>Default Settings>Plan, check "Ignore Casing for Opening Resize". Drag the doorway so that it fills the entire width, set the height appropriately, and I think you should be good to go. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted May 4, 2016 Share Posted May 4, 2016 I'm 100% with Michael on this. Link to comment Share on other sites More sharing options...
HamlinBC Posted May 4, 2016 Share Posted May 4, 2016 Either that or use soffit...and leave the ceiling height at 12'. Link to comment Share on other sites More sharing options...
SNestor Posted May 4, 2016 Author Share Posted May 4, 2016 On 5/4/2016 at 8:48 PM, Alaskan_Son said: I believe the source of your problem is that dropped ceiling and the corresponding top section of wall that is automatically created (thereby changing the way that invisible wall works). I just don't think the invisible wall method works very well in that situation. I would use a Doorway. Just suppress the casing and Edit>Default Settings>Plan, check "Ignore Casing for Opening Resize". Drag the doorway so that it fills the entire width, set the height appropriately, and I think you should be good to go. On 5/4/2016 at 8:54 PM, Joe_Carrick said: I'm 100% with Michael on this. Thanks guys...that is the answer. Just seems counterintuitive... But...it works. Link to comment Share on other sites More sharing options...
