nick66 Posted April 21, 2016 Share Posted April 21, 2016 I'm using the technical illustration for my exterior elevation views. Only about half of the siding is showing up in the view. can anyone tell me why? Do most of you guys use cross section vector view for exterior elevation Link to comment Share on other sites More sharing options...
joey_martin Posted April 22, 2016 Share Posted April 22, 2016 Until the live elevations, which I don't use that often, I have never used anything other than a vector view camera for elevations and sections. Link to comment Share on other sites More sharing options...
Chopsaw Posted April 22, 2016 Share Posted April 22, 2016 Nick, I think you may be facing the same issue that was discussed last week, take a look at these settings I discussed here, https://chieftalk.chiefarchitect.com/index.php?/topic/9213-brick-pattern-issue/ If not post you plan and I will take a look tonight. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted April 22, 2016 Share Posted April 22, 2016 In plot lines the lines seem to work better b/c you can use your line weights from any layer-set you want. Using live view, you cannot use line weights, you have to use what Chief gives you, whatever that is. for elevations ,I use plot lines with shadows Link to comment Share on other sites More sharing options...
Chopsaw Posted April 22, 2016 Share Posted April 22, 2016 Nick, I did a little more checking into the situation for you and noticed that the adjustments that I mentioned above only make a slight improvement. Not quite satisfactory. I checked a plan of mine that I have files for in X7 and X8 and there is a definite deficiency in the default settings with both versions of the software. Not quite as bad as your example but definitely visible. Personally I use Vector view for my elevations but a 3D Technical Illustration often works well when printed in B&W. So there is a setting for Line Thickness that will improve the situation thanks to Perry I decided to look for that and found that it works ok. See attached .jpg's. I also noticed that turning on the colour seems to help with line weight and consistency. As well I often do that with my 3D illustrations to give a little more depth with shading even when printed in B&W. If anyone has more to add to actually solve the problem that would be great as this seems more like a work around to me. Hope this works for you for now. Link to comment Share on other sites More sharing options...
