Room Definition Line or Single Line Wall
buzzsaw204
Go to solution Solved by Alaskan_Son,
By the way, you shouldn't lose your room definition simply by turning off those invisible walls.  I think you might be mistaken.  It works for me.  You could also just do that and draw a polyline around that room if you wanted.
yes, i know that you dont lose the Rm Def. lines.
what i meant is that....if it's turned off, theres no Line defn. for the Porch area.
yes, you're right. just manually draw Rectangle using CAD Line. thats what i was trying to avoid to have to do.
I won't claim to understand this issue all that well as I haven't studied it much so I could be wrong, but I believe that happens in any situation where the new room definition requires any kind of structural change.  I believe the only place a zero width room divider really works is where all you want to change is the finish flooring.
