stager386 Posted March 10, 2016 Share Posted March 10, 2016 Does anyone know how to create a different material region on the floor that has an unusual shape? Link to comment Share on other sites More sharing options...
jscussel Posted March 10, 2016 Share Posted March 10, 2016 Use the "Floor Material Region" tool and shape it as you want. What version are you using? Link to comment Share on other sites More sharing options...
stager386 Posted March 10, 2016 Author Share Posted March 10, 2016 Thanks Jon. I am using X8. But I cannot make the floor material the shape I need. I've attached the floorplan. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 10, 2016 Share Posted March 10, 2016 Select the Floor Material Region and use the "Break Tool" to add vertices. Then grab the edit handles and move to the locations where you want them. You can also change a segment to an arc if needed. Editing the Material Region is just like any other Polyline object. Link to comment Share on other sites More sharing options...
rlackore Posted March 10, 2016 Share Posted March 10, 2016 To add to what Jon and Joe said, you can also create a closed polyline, edit it's shape to whatever you need, then convert it to a material region using the convert polyline tool. Link to comment Share on other sites More sharing options...
DMDesigns Posted March 10, 2016 Share Posted March 10, 2016 The real question is, how come it does not flush the top of the tile to the wood..? --Dave Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 10, 2016 Share Posted March 10, 2016 The real question is, how come it does not flush the top of the tile to the wood..? --Dave Simple answer. The Material Region is a different thickness than the Floor Finish. The Material Region only cuts down to the sub-floor. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 10, 2016 Share Posted March 10, 2016 Joe is correct. Increase thickness of one or more of the layers to bring flush or uncheck Cuts Finish Layer of Parent Object. Link to comment Share on other sites More sharing options...
stager386 Posted March 11, 2016 Author Share Posted March 11, 2016 Thank you everyone!! My next issue......I want to remove the tiled ceiling and paint the exposed ducts and pipes. This is a basement remodel. Do I need to learn how to build the ceiling to show the things that are normally covered? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 11, 2016 Share Posted March 11, 2016 Thank you everyone!! My next issue......I want to remove the tiled ceiling and paint the exposed ducts and pipes. This is a basement remodel. Do I need to learn how to build the ceiling to show the things that are normally covered? Yes. You'll need to remove any ceiling finish layer(s), build framing for the floor or ceiling above, and you'll need to learn how to model the ducts and pipes as well. Link to comment Share on other sites More sharing options...
rlackore Posted March 11, 2016 Share Posted March 11, 2016 Build the floor/ceiling framing, either manually or automatically. Open the Room Specification dbx and remove the ceiling finish. This will expose the floor framing and/or the ceiling joists above. Link to comment Share on other sites More sharing options...
stager386 Posted March 11, 2016 Author Share Posted March 11, 2016 I guess I can't build framing. I have Interiors. Not Premier. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 11, 2016 Share Posted March 11, 2016 So you would need to use PSolids or Molding Polylines for the framing. Link to comment Share on other sites More sharing options...
