SapPata Posted February 20, 2016 Share Posted February 20, 2016 Dear friends. My Room divider below just draw as a 1 Line. I want it show as a 2 Lines. How to change this ? Best regards Link to comment Share on other sites More sharing options...
michaelgia Posted February 20, 2016 Share Posted February 20, 2016 Use invisible wall then Link to comment Share on other sites More sharing options...
tommy1 Posted February 20, 2016 Share Posted February 20, 2016 The room divider turns into an invisible Interior 4 wall when you change the structural properties on either side of the room divider. So just place an interior 4 wall and make it invisible. Link to comment Share on other sites More sharing options...
dshall Posted February 20, 2016 Share Posted February 20, 2016 The room divider turns into an invisible Interior 4 wall when you change the structural properties on either side of the room divider. ....... Does this make sense? I don't mean to say "does Tommy's statement make sense", I am asking if the wall changing makes any sense. BTW Tommy, thanks for this insight. Truly, why would anybody want the wall to change to an invisible interior 4 wall because I changed the ceiling height on one side of the room divider. This is the kind of stuff that must drive people nuts. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 20, 2016 Share Posted February 20, 2016 I think the reasoning behind it is ,that if a platform height changes , then there will be some kind of framing to fill the gap. They work good for those pesky ceiling and floor fills. Link to comment Share on other sites More sharing options...
glennw Posted February 20, 2016 Share Posted February 20, 2016 Select the Room Divider wall and open it's dbx. On the General panel, change the thickness to whatever you want. The beauty of doing it this way is that Chief will automatically create a new wall type that is invisible room divider wall and the thickness that you specified. The new wall type is added to the will types list named something like "Room Divider-100". The 100 is the thickness - 100mm in this case. Link to comment Share on other sites More sharing options...
