ACADuser Posted December 3, 2015 Share Posted December 3, 2015 I am trying to use 2 lines as a trim fence & trim between them in section view. Works fine in plan view but not in section view. Is that normal? Link to comment Share on other sites More sharing options...
DavidJPotter Posted December 5, 2015 Share Posted December 5, 2015 Alan, that kind of operation works just fine on my PC in elevation, so perhaps it is your PC or your Preferences which is the problem. DJP Link to comment Share on other sites More sharing options...
ACADuser Posted December 5, 2015 Author Share Posted December 5, 2015 David, I draw a tic tac toe with 4 lines. Select one line & see the trim icon appear Then I shift select the second parallel line and the trim icon disappears. You get something different? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 5, 2015 Share Posted December 5, 2015 Why do you need to shift select the second line? Link to comment Share on other sites More sharing options...
ACADuser Posted December 5, 2015 Author Share Posted December 5, 2015 Because I want to trim between the two lines. Like this. I did this in plan view. Link to comment Share on other sites More sharing options...
glennw Posted December 5, 2015 Share Posted December 5, 2015 Alan, For some reason, in section view, you need to block the 2 trim lines together and then do the trimming. Link to comment Share on other sites More sharing options...
ACADuser Posted December 5, 2015 Author Share Posted December 5, 2015 Well there is no good reason !@#$%! I'm just laughing a shaking me head. Just can't believe it. Link to comment Share on other sites More sharing options...
ACADuser Posted December 5, 2015 Author Share Posted December 5, 2015 Just submitted a Bug report. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 6, 2015 Share Posted December 6, 2015 Because I want to trim between the two lines. Like this. I did this in plan view. Gotcha. Looks like a bug to me too. Needs to be fixed. In the meantime, you can do as Glenn suggested, or you can temporarily connect the 2 lines to create one single polyline and then do your trimming. Link to comment Share on other sites More sharing options...
