Bug with upgrade 16.2.0.47x64
JeanTurcotte
Richard,
What we really need is just an image showing your entire Chief window so we can see the location of all your toolbars and Side Windows(library,project browsers...etc).
If you are using Windows 7 you can using the Snipping tool included with the OS to do this.
Brian,
I reinstalled the 16.3 release and turned off the option "Scale Toolbar Icons for High DPI." and my problem desappeard . Yeah !!! The Icon are a bit small but I can live with it. I also joined a capture of my  display.
Thank's for all of you, you make my day...
Jean
That worked for me too, but the icons are unusably tiny on my high DPI laptop.
We noticed that the problem has to do with the edit toolbar not having enough reserved space. The view resized smaller to provide space for the edit toolbar causing a redraw.
Here is another option if you want the icons properly scaled:
Create a toolbar with 1 item in it and place it at the bottom of the screen where the edit toolbar normally shows up. Make sure it is turned on in Elevation and 3D Views. This will force the space for the edit toolbar to be properly reserved before selecting anything in a new 3D view.
