im trying... roof woes
Randyc
Go to solution Solved by Randyc,
pull the ridge end back as shown in the left picture.  The as in the middle picture, break the roof plane in a couple spots.   Then join the roof edges as shown in the right picture.
Sorry...explaining in text isn't one of my strengths.  Hope the pictures work or if someone else can explain it better.  I need to get something to be able to do short videos.  I think I can explain things better that way.
Hope it helps.
Randy, you use the break tool (hot key 3) at the critical points and then join the roofs (hot key 2) with the join tool. When I do this I work in plan view. Study the roof plan in plan view with his fix and you can see how to make these types of roof configurations work.
