Alaskan_Son Posted September 17, 2015 Share Posted September 17, 2015 Thanks you all for the help... i added siding to exerior walls and it helped... still some problems to work out but its getting there... Thanks again Randy You know what...thank YOU for posting the plan. It is EXTREMELY helpful. In fact I'm going to start giving people points for posting the plan. Giving you one right now. Link to comment Share on other sites More sharing options...
HumbleChief Posted September 17, 2015 Share Posted September 17, 2015 You know what...thank YOU for posting the plan. It is EXTREMELY helpful. In fact I'm going to start giving people points for posting the plan. Giving you one right now. That's a great call Michael - automatic points for posting the plan. Link to comment Share on other sites More sharing options...
HumbleChief Posted September 17, 2015 Share Posted September 17, 2015 Hope this helps with your upcoming structure problems. 3 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 17, 2015 Share Posted September 17, 2015 Thanks Larry!! Good stuff. I personally just learned a lot from that. You get another point. Link to comment Share on other sites More sharing options...
johnny Posted September 17, 2015 Share Posted September 17, 2015 Yeah, good stuff Larry. Can you ruby script that selection process you did Larry? It would be nice to have some custom selections as a button of per-determined criteria. Link to comment Share on other sites More sharing options...
glennw Posted September 17, 2015 Share Posted September 17, 2015 Johnny, Doesn't the floor default setting do what you are asking. Set your floor defaults to match that large room (or whatever you want). Then just set each room to use the default - which it should do automatically unless the default is unchecked and changed on a room by room basis. Link to comment Share on other sites More sharing options...
HumbleChief Posted September 17, 2015 Share Posted September 17, 2015 Johnny, Doesn't the floor default setting do what you are asking. Set your floor defaults to match that large room (or whatever you want). Then just set each room to use the default - which it should do automatically unless the default is unchecked and changed on a room by room basis. We are going to have to wait a long time for Glenn to get something wrong. Setting the defaults room by room should work as well. 1 Link to comment Share on other sites More sharing options...
Randyc Posted September 18, 2015 Author Share Posted September 18, 2015 wow thanks Link to comment Share on other sites More sharing options...
HumbleChief Posted September 18, 2015 Share Posted September 18, 2015 You have to use the match properties button first. Link to comment Share on other sites More sharing options...
