DB-Designs Posted September 13, 2015 Share Posted September 13, 2015 I downloaded a stone image from a manufactures website to put on the fireplace as a new texture. I have messed with the scale of the texture every way I can think of to show the texture properly. How do I scale the texture so it doesn't look like a tiled image on the walls? I have attached an image showing the "tiled" look I'm referring to. Thanks for the help! Link to comment Share on other sites More sharing options...
Kbird1 Posted September 13, 2015 Share Posted September 13, 2015 is it this issue ? https://chieftalk.chiefarchitect.com/index.php?/topic/6435-materials-not-mapping-to-sketchup-objects-properly/#entry57417 otherwise post the plan so someone can look at settings. Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 13, 2015 Share Posted September 13, 2015 Good texture files are large. The larger the texture file the better. Scaling is not the most important factor. How the texture is cropped determines how it looks when applied to a surface. The texture has to be large enough and skillfully cropped so that when it repeats, it is less noticeable. DJP This You Tube video may be helpful to you: https://www.youtube.com/watch?v=oy2cwSV0Iys Link to comment Share on other sites More sharing options...
Kbird1 Posted September 14, 2015 Share Posted September 14, 2015 that is true for something that large you may need to look for a Seamless Texture. Link to comment Share on other sites More sharing options...
KirkClemons Posted September 14, 2015 Share Posted September 14, 2015 I downloaded a stone image from a manufactures website to put on the fireplace as a new texture. I have messed with the scale of the texture every way I can think of to show the texture properly. How do I scale the texture so it doesn't look like a tiled image on the walls? I have attached an image showing the "tiled" look I'm referring to. Thanks for the help! The images will need to be photoshopped into a seamless texture in order to remove the 'tiled' effect. Scale and size won't have a desired effect in this case. Link to comment Share on other sites More sharing options...
DB-Designs Posted September 14, 2015 Author Share Posted September 14, 2015 Does anybody know if "paint" in windows 8 will work before I purchase Photoshop? I'm trying it now, but I don't know if I'm doing it correctly because it still looks "tiled". Link to comment Share on other sites More sharing options...
HamlinBC Posted September 14, 2015 Share Posted September 14, 2015 Use GIMP, it's an open source Photoshop. Just to take out any guess work, here's a link: http://www.gimp.org/downloads/ Link to comment Share on other sites More sharing options...
KirkClemons Posted September 14, 2015 Share Posted September 14, 2015 Does anybody know if "paint" in windows 8 will work before I purchase Photoshop? I'm trying it now, but I don't know if I'm doing it correctly because it still looks "tiled". I use GIMP to do most of my textures. There are even a few plugins that work well with it. You can download it from here: http://www.gimp.org/ Also, you may take a look at this app, it does a decent job with most images: http://www.bundysoft.com/wiki/doku.php?id=projects:johnj Link to comment Share on other sites More sharing options...
DB-Designs Posted September 14, 2015 Author Share Posted September 14, 2015 Thanks everybody!! I will work with this and let you know how it goes and/or if I have any other questions. Link to comment Share on other sites More sharing options...
DB-Designs Posted September 14, 2015 Author Share Posted September 14, 2015 OK......I have to admit.......I have no idea what I'm doing with GIMP (photoshop). I opened the image in GIMP......I've cropped it, cut it, resized it, etc. etc......and then exported it to my desktop. When I create a texture with the new image, I still get the "tile" effect, when I apply it to the fireplace wall. I'm really not sure what to do from this point. Is there an answer? Should I export it from GIMP as a different file format? HELP!!! Link to comment Share on other sites More sharing options...
KirkClemons Posted September 14, 2015 Share Posted September 14, 2015 If you want, you. Can attach the original and I'd be happy to take a look. Link to comment Share on other sites More sharing options...
DB-Designs Posted September 15, 2015 Author Share Posted September 15, 2015 I tried to attach the drawing file and it said the file is too big! Sorry.... Link to comment Share on other sites More sharing options...
Kbird1 Posted September 15, 2015 Share Posted September 15, 2015 I tried to attach the drawing file and it said the file is too big! Sorry.... try zipping it and then attaching..... it must be under 25mb to attach. Link to comment Share on other sites More sharing options...
Rich_Winsor Posted September 15, 2015 Share Posted September 15, 2015 OK......I have to admit.......I have no idea what I'm doing with GIMP (photoshop). I opened the image in GIMP......I've cropped it, cut it, resized it, etc. etc......and then exported it to my desktop. When I create a texture with the new image, I still get the "tile" effect, when I apply it to the fireplace wall. I'm really not sure what to do from this point. Is there an answer? Should I export it from GIMP as a different file format? HELP!!! It sounds like you don't fully understand the concept of a "seamless texture". What you have to do in GIMP or PS or PSP is edit the edges of the texture so that when they are tiled they flow seamlessly from one tile to the next. Just cropping or resizing won't accomplish the effect you desire. Suggest you Google "Seamless Textures". You can find tutorials that explain the process for different image editors. Creating flawless seamless textures is somewhat of an art form. The attached thumbnail shows a seamless texture applied to a wall. Link to comment Share on other sites More sharing options...
KirkClemons Posted September 15, 2015 Share Posted September 15, 2015 I tried to attach the drawing file and it said the file is too big! Sorry.... I was just meaning you could attach the original image file that you want to turn into a texture. Unless you do a backup entire plan, the plan file won't have the texture anyway. Link to comment Share on other sites More sharing options...
DB-Designs Posted September 15, 2015 Author Share Posted September 15, 2015 It sounds like I just need to research and "practice" making seamless tiles, as Rich mentioned. Anyways, I attached the Chief file and the picture I copied right from the stone manufacturers website, if anybody is interested in taking a look at it. Thanks for all the help! Fireplace Stone Texture.zip Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 15, 2015 Share Posted September 15, 2015 In my opinion that particular image is going to be extremely difficult to turn into a seamless texture and even if someone does take the time to do it, it's still going to take on a tiled appearance. That Big Stone on the lower left is simply too distinctive for such a small sample area. You're going to see that same large recognizable stone repeat itself every 24" (or whatever it is) and you probably won't like it anyway. I would personally either find a much bigger sample image (of a bigger area) or just use another texture from one of the manufacturer libraries we already have that fits the bill (El Dorado stone for example has a lot to choose from). Link to comment Share on other sites More sharing options...
KirkClemons Posted September 15, 2015 Share Posted September 15, 2015 Try this out. Link to comment Share on other sites More sharing options...
