Sink in cabinet showing in reference display
Larry_Sweeney
What is the trick to show a sink in a base cabinet using the Reference Display? I'm doing a plumbing layout and was going to turn on the base cabinets with sinks on the floor above for referencing my drain lines. The base cabinet shows, but the sink in the cabinet doesn't. I played around with the reference display options and layers but I can't find the cure. Is there one?
No, I was wrong.  Turning on CAD, Default doesn't work.  It works for me if I turn on the Cabinet, Base layer though. First time I tried, the sink was barely visible.  2nd time it worked just fine though.  Not sure what the difference was.
Larry:
If you want to only see the sink and not all the base cabinets, in the Ref Display layer set, change the base cabinet line style to the "no line" style ... make sure the interior fixtures layer is on ... than you will only see the sink and not the base cabinet(s).  If you don't want to see some of the other interior fixtures, you'll have to assign them to a different layer.
