Rendering help
SNestor
Wondering why the cabinet glass is solid gray instead of clear like it should be. What am I doing wrong? Also - the table behind the couch is white marble...but it's washed out.
I rendered this over night...so there were a lot of passes. This is only my 2nd or 3rd try at creating a decent render - and my results are based solely on pure luck and great software. post-227-0-68270400-1439849175_thumb.jpg
Steve,
Obviously you meant "Ray Trace" vs "Rendering".
I can only assume you are using X7 since you don't have that info in your signature.
You probably don't need more than about 4-5 passes to get a good Ray Trace.
Why is the cabinet door glass not transparent?  No way to tell - post the Plan.
The marble maybe set as "matte" in the material's properties ?
with glass it may depend on how the light hits it and whether you use photons and caustics etc but I am no expert on Ray Tracing for sure .
Posting the plan with your camera saved is probably the fastest way to a good answer....
some notes I made from here on the Forum from Jintu and others
Raytrace Settings-Forum Notes.pdf
