LeeDrafter
hello,
I am drawing a CAD detail that involves hidden (dashed) lines that are only 3" long. I selected the smallest dashed line from the drop-down menu, but it still only shows as a solid line. The dashes don't show when I print from layout either. I have read through forums a bit before I decided to ask this question- so I made sure the page setup dbx says line weight of 1=1/100 mm. I don't know if that has anything to do with my problem or not. All I want is to be able to draw a very short dashed line and still be able to see the dashes. The dashes are visible if I toggle off the lineweights, but that won't do me much good if it doesn't print that way. I appreciate any help- Thanks!
There is a "create line style" tool in Chief, try it. If your having a printing problem just increase the line-weight of the line. out of the box it might be set to 1, I use 12 to 200 depending on what I need. I would keep that 1=100 the same and change line weights as needed. It does mean to go through all your layer-sets and change them but once set up you wont have to do it again if you use templates
hello,
Very  difficult to answer.  Many different reasons for this behavior.  If you want an answer,  I would be willing to look at it if you post the plan with layout.  To do this,  with layout selected go to  FILE<BACK UP PLAN ENTIRE PLAN and save this to a new folder and post or provide a drop box link to access large files.
