Alfiejay Posted June 13, 2015 Share Posted June 13, 2015 I have created a model for a yacht but my lower floor is missing. I needed 4 levels so I created a basement level, and 3 other floors. On the basement level, the water is coming through the wall and the floor is missing over most of that level. Can anyone give me any suggestions on how to fix? I tried to upload the file but it was too large. Any help would be greatly appreciated. Thank you, Alfiejay Link to comment Share on other sites More sharing options...
lbuttery Posted June 13, 2015 Share Posted June 13, 2015 Hi: you will probably need to post your plan to get more than guesses this forum is for Chief Premier users HD Pro users can benefit from following this forum but you should also check out the Hometalk forum Lew Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 13, 2015 Share Posted June 13, 2015 You can also use Dropbox to share the plan file. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 13, 2015 Share Posted June 13, 2015 do a "save as" of your plan and make a copy and delete out anything we don't need to look at like fixtures and furniture etc. M. Link to comment Share on other sites More sharing options...
Alfiejay Posted June 15, 2015 Author Share Posted June 15, 2015 Okay, thank you. I am not sure how I got on this forum. I meant to get Hometalk. I did re-post on that site and thanks Mick because after I took everything out, it did upload. If you guys would still like to see if you can figure out what I am doing wrong, I have added the attachments on the Hometalk site. Thanks so much for your help. I will post on the correct site. Alfiejay Link to comment Share on other sites More sharing options...
antoine Posted June 15, 2015 Share Posted June 15, 2015 interesting. have you made the hull walls? Link to comment Share on other sites More sharing options...
