Migaloo Posted August 17 Share Posted August 17 Not sure what is happening with these lines or why they are even there. Any thoughts of what's doing this? side view of roof.pdf Link to comment Share on other sites More sharing options...
Migaloo Posted August 17 Author Share Posted August 17 Also when sending this to the layout it has two spots with no roof image... side view of roof 2.pdf Link to comment Share on other sites More sharing options...
Gawdzira Posted August 18 Share Posted August 18 Posting the plan file would be helpful. 2 things come to mind that could be causing this 1. check your distance from the origin. Select an object and look on the lower portion of the screen to see where it is located in space. If your model was built a long way from the origin you can get texture issues. 2. Check the thickness of the roof surface finish material. Make it bigger (3/4") and see if that solves it Link to comment Share on other sites More sharing options...
Migaloo Posted August 18 Author Share Posted August 18 Rocky Grant 1 (4).zip I attached the file. See what you think. Thanks Link to comment Share on other sites More sharing options...
KenL-sdd Posted August 18 Share Posted August 18 The file has the roof off to the side. Link to comment Share on other sites More sharing options...
Mark3D Posted August 18 Share Posted August 18 (edited) If I delete the curve part of the roof the problems goes away, as a fix could the curved portion be done with a molding polyline you would be missing ridge capping so may not be suitable, hopefully others will have a better solution Edited August 18 by Mark3D Link to comment Share on other sites More sharing options...
Solution Migaloo Posted August 19 Author Solution Share Posted August 19 Yes I built the roof off the house. Its easier that way. I was able to fix one of the holes in the roof by moving an interior wall slightly. The diagonal lines I will edit on the layout. Thank you for looking at this for me. Link to comment Share on other sites More sharing options...
