PitMan71 Posted June 1 Share Posted June 1 I am trying to export jpg images straight from chief floor plan. Anybody got any suggestions to make the image sharp? No matter what resolution I export to the image is grainy.... I am able to get a sharper image by exporting to PDF first and then using preview to export to jpg. Seems like there should be a more direct way. Thanks Link to comment Share on other sites More sharing options...
robdyck Posted June 1 Share Posted June 1 As far as I know, using a convert pdf to jpg tool is still the simplest way. 1 Link to comment Share on other sites More sharing options...
Solution DBCooper Posted June 2 Solution Share Posted June 2 As far as I know, Chief will only let you export a picture of a plan view using the actual screen pixels, so increasing the DPI will just make the image dimensions smaller. BTW, you can export a picture from a camera view using a much higher resolution, just not plan views. You can do the pdf trick or maybe you could export it as a cad file (dwg) instead. 1 Link to comment Share on other sites More sharing options...
glennw Posted June 3 Share Posted June 3 (edited) Does exporting as a Metafile work (.emf or .wmf)? I can't try it out as metafiles are not supported on mac. Edited June 3 by glennw Link to comment Share on other sites More sharing options...
PitMan71 Posted June 4 Author Share Posted June 4 On 6/2/2026 at 5:17 PM, DBCooper said: As far as I know, Chief will only let you export a picture of a plan view using the actual screen pixels, so increasing the DPI will just make the image dimensions smaller. BTW, you can export a picture from a camera view using a much higher resolution, just not plan views. You can do the pdf trick or maybe you could export it as a cad file (dwg) instead. This is good to know. Thanks. Link to comment Share on other sites More sharing options...
