Plan Elevation "Shortcuts"
Hello All!
Does anyone know if there is a viable way (that I can't figure out) to create a toolbar button for custom elevation presets?
For example:
If I use the standard "Wall Elevation" tool button, Chief will create my wall elevation using whatever my default settings are set at under Camera Tools > Wall Elevation in the plan file (i.e. what dimension defaults it uses, which layer it lives on, etc.)
I'd like to be able to create a custom toolbar button for various types of elevation presets.  If I am doing an Electrical elevation, I want to designate that from the beginning the dimension defaults are my electrical dimensions, and that it is on a special electrical layer, that it is clipped in a certain way, etc.
I know I can change all of these manually in the object dialog after I have created a view, but it would be great from a workflow perspective to just use a preset, so my cabinet elevations don't show on my electrical layer and so on.  I seem to spend a lot of time changing clips, re-labeling and re-layering things lol.
Am I dreaming a pipe dream?
Thanks in advance!
Would default sets be what you're looking for?
You can setup all your presets in there, and when you pull your elevation view, you can select which default set you want that has all of that information setup on the back end.
Here's a snip of the Default Set dialog box that allows you to change the aspects of each Default Set.
So essentially you would create new (or use existing) settings for each of these items.  They would be custom to whatever Default Set you're wanting.
Hi Jonathan,
The Default Sets option does do some of the elements of what I am after, but it doesn't allow me to set the default layer for the elevations or specific clippings, etc.  If what I was after isn't feasible, it's definitely a "halfway" bridge.  Was just trying to get everything in one pop.  :-)
31 minutes ago, HannahKucerova said:
Hi Jonathan,
Default sets include layersets.  That should handle everything.
Yes, they do. But unless I am missing something very obvious, even when using these custom defined default sets (which I do use and have several custom default sets set up for my workflow), all of my newly created elevations get set to whatever layer I have put in the Cross Section/Elevation defaults. There is also no option to control the individual camera/section settings, which is another thing I was hoping to streamline.
You can change the different camera elevation defaults to be more "standard" to what you do 80% of the time.  But you're right...you cannot have different "types" of wall elevations.
The only thing you can do is set your wall elevation default, and create a bunch of different default sets that are what you're looking for.  When you pull your wall elevation or exterior elevation, or cross section, then you change your default set in that particular camera view.
In reality...probably same amount of clicks.
...I have multiple cross sections in my template plan, one for stairs, one for garage, a few for kitchen... so I am not changing the layerset and back clip all the time
you may be able to do the same thing with wall elevations, and/or use the "clip to room" feature of a section (not sure if you get the same result as wall elevation)
I think adding Multiple Saved Defaults for Cameras and that adding those to Saved Plan Views/Default Sets would be a good suggestion.  In the meantime, here's an idea you might consider as a stopgap:
"Manual Saved Defaults" :
  1. Set up a series of different cameras that have all your desired settings and label them appropriately.
  2. Place them all in a strategic easy to find location in your plan.
  3. Create a special Plan View where only those cameras are displayed.
  4. When you are about to create a new camera view and want to use one of your "Manual Saved Defaults", switch to that special Plan View, select the appropriate camera, and click the Set as Default tool in your Edit toolbar.
  5. Now go back to your previous Plan View and create your camera.
Edited by Alaskan_Son
All...thank you!  There are several good suggestions here with ideas I have not been utilizing.  I think a combination of a few options here will help do a little streamlining. I think Michaels idea also might cover another peeve of mine as well, so kudos!
@SHCanada2, Jason, I am going to ask what might be a really, really dumb question.  If you have a template plan with multiple cross sections already placed (I'm going to assume they are like in a designated area off to the side), how do you move them to actually cover the intended area?  For example, if you have one for stairs and you design a house where the staircase is turned a different direction than you cross section is facing, how do turn the pre-placed cross section camera?
you cant, you need two(or 4 depending on how finicky one is. I and others have put in a suggestion  to CA to be able to rotate cameras. I will admit I only have two, and sometimes I will recreate, because I prefer a certain direction. So it is a bit of a "I should update my template" thought in my mind, but then forget to do it
For instance my kitchen and bath view has this for kitchens. I then just pick the 2 or 3 (if there is an island) that directionally work. IF I'm lucky my template layout (which is already connected to two of them) works, if not I have to relink the callout to the one that applies:
my plot plan view has fences, construction lines which act as property lines so they show up in elevation, Two elevation regions for a typical front to back slope. You can see all the cross sections below
I use a thin solid to get a cleaner looking grade line, the other thin solid is there to show max bylaw height.
so yeah, a lot of things going on. If i dont need them, I just move them off the page, although the sections are off the page to begin with
If I was smarter I suppose I might color the cross sections based on what they are, as the PIA is opening the object to check the name to see what it is. Although I keep the  stair  section narrower so I know that is the one
Edited by SHCanada2
@SHCanada2  Okay, I gotcha.  Once upon a time I had considered adding pre-defined cameras to my base template plan but the one time I tried it I couldn't move them to where they needed to be, so I was like, bleh, forget this.  I've found that in some areas where I thought having predefined items on my templates would be helpful, I spent more time deleting and recreating them because that particular plan didn't "conform".  I thought I had missed something crucial this whole time, ahaha.
yeah I have that issue more with layouts, having to delete pages or move them around. but the section cameras are off to the side to begin with so they dont require any work. Although sometimes I am too lazy to go fetch the right one (by opening the each to find the right one) .
..its all a trade off :o) and half the time I don't remember some of the things I have positioned off to the side on my template.
