wjwbuilder Posted May 6 Share Posted May 6 Can't place a gable vent in a gable end wall that is an attic. Any help would be great thanks Link to comment Share on other sites More sharing options...
Doug_N Posted May 6 Share Posted May 6 please post a plan file so that we can see what the problem is and suggest a possible solution. Link to comment Share on other sites More sharing options...
wjwbuilder Posted May 8 Author Share Posted May 8 Thanks for having a look Doug_N I been drawing in Chief since the company started, I'm old LOL Never had this problem before. This is drawn in X-17 one story building with truss roof. I have not built the framing yet. So Just 2x6 walls and the attic or gable walls are built by x17 itself. But still a large attic area in a truss system. I would like to place a 8/12 gable vent. I've done it a million times. I could build a polyline solid and fake it but I would like not to have to do that. Thanks again. Gable ends I would like place siding vents for attic air.pdf Link to comment Share on other sites More sharing options...
JonathanK Posted May 8 Share Posted May 8 Are you talking about a window and making it louvered, or are you talking about a symbol out of the library? Link to comment Share on other sites More sharing options...
wjwbuilder Posted May 8 Author Share Posted May 8 Symbol from the Core library Round Vents and Gable vents that match the roof pitch and belong tight to the peak. Thanks, Bill Link to comment Share on other sites More sharing options...
JonathanK Posted May 8 Share Posted May 8 Have you tried using a window and switching the type to Louvered. I'm curious if it's the wall, or something else... Link to comment Share on other sites More sharing options...
DBCooper Posted May 9 Share Posted May 9 I am not having any problems placing one from the library. You need to post an actual plan file so that someone can see what is going on in your plan. A pdf with a picture doesn't help in this case. 1 Link to comment Share on other sites More sharing options...
NRST8TRKR Posted May 14 Share Posted May 14 Can't place a gable vent in a gable end wall that is an attic. Any help would be great than Is this what you are looking for? X-17, 8/12 roof, 8/12 Attic Gable vent ,no problem here. Link to comment Share on other sites More sharing options...
Doug_N Posted May 14 Share Posted May 14 On 5/6/2026 at 10:00 AM, wjwbuilder said: Can't place a gable vent in a gable end wall that is an attic. Any help would be great thanks You need to post the actual plan file "somename.plan" and not a pdf. That way someone will be able to look at the model and perhaps figure out what is wrong with the build 1 Link to comment Share on other sites More sharing options...
wjwbuilder Posted May 21 Author Share Posted May 21 Thanks all for your replies, if everyone can do it then I will figure it out. Link to comment Share on other sites More sharing options...
tundra_dweller Posted May 21 Share Posted May 21 I just ran into this problem as well. If you're trying to place the vent in a 3d camera view, try placing it in plan view instead, at your attic level. I've also run into problems placing these when you have an attic wall running perpendicular to your gable end in the space where you want your vent. Link to comment Share on other sites More sharing options...
