decorators3 Posted 5 hours ago Share Posted 5 hours ago Hi I built three houses next to each other , they will be on a sloped terrain but when I created the sloped terrain the houses do not follow the slope. they look like they are floating How do I make adjustments Cheers Link to comment Share on other sites More sharing options...
Rookie65 Posted 4 hours ago Share Posted 4 hours ago Lower the floors Link to comment Share on other sites More sharing options...
glennw Posted 4 hours ago Share Posted 4 hours ago (edited) No. I think it better to raise the terrain. Have you drawn your houses on the same level? I assume that you have drawn them on different levels. Open the Terrain Specification dbx and go to General page. Check Auto Build Terrain. Uncheck Automatic. Look this up in the help file and then have a play with entering different values (including negative values) for Subfloor Height Above Terrain. Edited 4 hours ago by glennw Link to comment Share on other sites More sharing options...
Rookie65 Posted 4 hours ago Share Posted 4 hours ago (edited) If the terrain is sloped, then the main floor level needs to be lowered to keep it in relation to the grade. That's what I meant by lowering the floors. Adjust the subfloor levels in the negative direction to where it needs to be Edited 4 hours ago by Rookie65 Link to comment Share on other sites More sharing options...
Renerabbitt Posted 3 hours ago Share Posted 3 hours ago I would suggest you draw your houses in 3 separate plan files and then reference them to each other, that way you can draw all houses at a subfloor 0 Link to comment Share on other sites More sharing options...
decorators3 Posted 3 hours ago Author Share Posted 3 hours ago thank you all for your feedback Greatly appreicated!! Link to comment Share on other sites More sharing options...
decorators3 Posted 47 minutes ago Author Share Posted 47 minutes ago 3 hours ago, Renerabbitt said: I would suggest you draw your houses in 3 separate plan files and then reference them to each other, that way you can draw all houses at a subfloor 0 I understand drawing houses in 3 separate plan files but where can I find info on how to reference them Link to comment Share on other sites More sharing options...
