58 minutes ago, SHCanada2 said:
I think you have to play with the pitch and rotated angle of the roof plane.
But then again, maybe there is a simpler way
sounds like it could work I'm working on a few ways trying to figure it out.  I have to say the responses I receive from this forum is amazingly helpful
Thank you
A warped roof like what you seem to want is either a roof-framers nightmare or his crowning achievement, as it will require tiny pitch changes with each set of rafters, bending sheathing, and more fun things.  Also, it is impossible to draw using Chief roof tools, which only produce flat planar or cylindrical surfaces.
Gene speaks truth.
i would pass on framing that. Without flat roof planes, it won’t be able to be prescriptively designed and wait till you get the bill from a structural engineer.
maybe they could 3-D print it out of a large scale plastic printer and just crane it into place
4 minutes ago, para-CAD said:
Gene speaks truth.
h ha got ya
I appreciate your response and will inform the client
I think the roof is flat, but it is certainly not trivial. I actually did something similar on my attached garage in order to have the roof ridge be below a window at the house. I spoke to the truss guys and they were a little surprised at what I wanted. I describe it to them as reducing the peak of each truss from front to back by 1/2 inch so when I got to the house, it was 3 inches shorter.
Trusses are engineered by their design software.
If this is stick framed with a structural (curved) ridge for a cathedral look..................it's all do-able but the cost just went up.
Not just bending roof plywood or 1x8s, but the interior ceiling surfaces all have to be curved (unless flat ceilings)
Crazy fun.  If they have the $$$ and desire.......go for it!
well its one of three for a builder.  so i'm going to call him tomorrow and discuss costs before
i go down the rabbit hole
1 hour ago, JiAngelo said:
How long is ridge beam span inside the building?  How far is it cantilevering past the windows to support the prow?  And is there a king post under the ridge beam splitting the window into separate units?
span is 40ft   cantilevering about 3 ft ( could be longer ) . as for the king post I don't know.. here's   the house idea he 's going for138108174_housesampleforca.thumb.png.851443c6e0e70531ff91d969a96008eb.png
9 hours ago, decorators3 said:
no .. not a curved roof just a slight gable uplift towards the front of the perch
then I see two different scenarios. 1. you can do it as I showed, or 2, build it with declining pitched full span trusses all the way to where the left of your blue line is.
I think 2, would be the better option, but to model it in chief, I think(but maybe others have a better way) you would have to create like 20 roof planes, each very narrow from the top down to the eave, and each with a slight decreasing pitch, from right to left. You could try start using 24" spacing for the roof planes, but I'd not sure how the 3d would look. my guess is it would show too disconnected at the top
If I were you, I'd call the truss company to see what their thoughts are
Edited by SHCanada2
Yes thanks for the options! i will take your advise and call the truss company
