terrain
decorators3
You don’t have to use project management if the old way suits you , you can turn  it off in preferences.
You navigate to plan file in project management right click export disconnected plan then save and place on forum it will even zip it if you want
If it fixed itself, then it was probably a rebuild terrain issue.  I have seen the program get the terrain out of date even with the auto rebuild on but if auto rebuild is off then it is usually out of date as soon as you make any changes.  The other thing that can cause something like this is a terrain hole.  That was going to be my first guess and if it wasn't that it was going to be a "post the plan" issue.
