usingchief Posted April 10, 2015 Share Posted April 10, 2015 I am befuddled. My task is to draw a corner of a room with a butt seam glass window. but can't figure out how to delete the vertical frame of a window and bring the glass to the corner of the room and to butt up against a glass panel 90 degrees from the first. I am sure it must be so easy but can't grasp the concept. Link to comment Share on other sites More sharing options...
rlackore Posted April 10, 2015 Share Posted April 10, 2015 I don't believe it's possible using Chief windows. However, if you would post a picture of exactly what you're trying to do (eg direct set window, commercial glass partition, etc) we could probably propose some work-arounds. Link to comment Share on other sites More sharing options...
John_Jones Posted April 10, 2015 Share Posted April 10, 2015 Probably the best one I have seen was done with the Pass-through window tool and a small invisible room. The glass in the windows are slabs. Don't forget to set your Plan Default to "Ignore Casing For Opening Resize" and turn off the frame on the pass-throughs. Link to comment Share on other sites More sharing options...
HumbleChief Posted April 10, 2015 Share Posted April 10, 2015 Michael, There's a bunch of videos out there dealing with this. I'll see if I can find a couple. Check this google search page -should keep you busy for a while. https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=corner%20window%20chief%20architect ..and a small reminder when looking for Chief answers techniques etc. Use google instead of the forum search just add Chief Architect to any term and you'll fin much more relevant info than the forum search. Link to comment Share on other sites More sharing options...
John_Jones Posted April 10, 2015 Share Posted April 10, 2015 I should have posted the image~! Link to comment Share on other sites More sharing options...
John_Jones Posted April 10, 2015 Share Posted April 10, 2015 Here is the plan file if you would like to look at the windows. corner window.plan Link to comment Share on other sites More sharing options...
HumbleChief Posted April 10, 2015 Share Posted April 10, 2015 Here is the plan file if you would like to look at the windows. That's probably the easiest method I've seen Thanks for posting that. Link to comment Share on other sites More sharing options...
usingchief Posted April 11, 2015 Author Share Posted April 11, 2015 GREAT ! Thanks for the assist. Link to comment Share on other sites More sharing options...
yusuf-333 Posted April 12, 2015 Share Posted April 12, 2015 I gave it a try to create a corner window symbol. Thought it could be an alternative way. Attached the pictures Link to comment Share on other sites More sharing options...
yusuf-333 Posted April 13, 2015 Share Posted April 13, 2015 I bet this is the easiest way with it! once you create the symbol, it is simply a window and not a big deal. I think the symbol creation and placement needs advanced techniques. I think people got confused on the concept, simply hope that helps. Attached the link of the plan that contains the window. https://docs.google.com/file/d/0BxgCyu8dBKtcanZpYTMzWUxtdWs/edit?usp=docslist_api Link to comment Share on other sites More sharing options...
MickeyToo Posted April 13, 2015 Share Posted April 13, 2015 Thank you, Yusuf. Not sure how you did it but very nice...and easy to use. You just have to be sure when you put them in the library to mark them Left and Right. Nice work! Link to comment Share on other sites More sharing options...
yusuf-333 Posted April 13, 2015 Share Posted April 13, 2015 Thanks Micky glad if that worked. I created it from a combined 3d molding p lines. I am working on creating more generalized symbol that every one will use it easily. Link to comment Share on other sites More sharing options...
jcaffee Posted April 13, 2015 Share Posted April 13, 2015 Very nice Yusuf! jon Link to comment Share on other sites More sharing options...
yusuf-333 Posted April 13, 2015 Share Posted April 13, 2015 Thanks Jon. one interesting property of this corner window is, when you tick the "system to supply a rectangular casing" in the symbol spc dbx you see the casing on both windows automatically. But the annoying thing is that I don't know why chief assigns the glass material to the casing and seems it can't be assigned casing material independently. The issue of framing, I think has no problem in accordance to chief's internal assumsions.it is the engineers task as for detail calks.in our area we use concrete structural framing and no problem to construct it. But since I am the structural engineer too, I understand timber structures and not difficult as such to apply struts and ties to support it. I don't know exactly but this issue was raised by a similar thread earlier. This is just to remind the areas that need improvements in relation to this topic. Thanks Link to comment Share on other sites More sharing options...
