PitMan71 Posted Monday at 03:33 PM Share Posted Monday at 03:33 PM I am trying to streamline the process of creating my area poly lines to have the color, fill, label, and schedule selections that I want. Living, Garage Porches, etc.... I have tried creating objects with the labels I want and adding to my library but that didn't work, program sees them a trim poly lines when I drag them into the drawing. Is there a way to accomplish this? It would be nice if I could invoke the polyline tool and it just draws it with the properties I want, but I haven't found a way to do that yet. Is there something I am missing? Thanks in advance. Link to comment Share on other sites More sharing options...
Renerabbitt Posted Monday at 10:01 PM Share Posted Monday at 10:01 PM 6 hours ago, PitMan71 said: I am trying to streamline the process of creating my area poly lines to have the color, fill, label, and schedule selections that I want. Living, Garage Porches, etc.... I have tried creating objects with the labels I want and adding to my library but that didn't work, program sees them a trim poly lines when I drag them into the drawing. Is there a way to accomplish this? It would be nice if I could invoke the polyline tool and it just draws it with the properties I want, but I haven't found a way to do that yet. Is there something I am missing? Thanks in advance. Just curious, why not use rooms to report area instead now that we have an OIP for floor defaults Link to comment Share on other sites More sharing options...
PitMan71 Posted Tuesday at 08:49 PM Author Share Posted Tuesday at 08:49 PM 22 hours ago, Renerabbitt said: Just curious, why not use rooms to report area instead now that we have an OIP for floor defaults I'm not 100% but it seems like early on this year when I first starting using Chief, there was some uncertainty about the calculations and I opted to go the route of poly lines so that I was sure of the reported numbers. Is that included OOB or what kind of setup is involved? If it makes life easier, it's worth at least giving it a try. Send me some info or a link to check out. Thanks Link to comment Share on other sites More sharing options...
Gawdzira Posted Wednesday at 12:33 AM Share Posted Wednesday at 12:33 AM See if this is what you are after. I did this quickly to spit out a tabulated list for some site area calculations. I did not refine this and you could easily lose the labels and use the names of the individual areas (renaming the headings). I did not try to copy these polylines into a new plan yet but I suspect they would retain the schedule association. RIC As Built V1p.zip 1 Link to comment Share on other sites More sharing options...
PitMan71 Posted Thursday at 02:06 PM Author Share Posted Thursday at 02:06 PM On 5/6/2025 at 7:33 PM, Gawdzira said: See if this is what you are after. I did this quickly to spit out a tabulated list for some site area calculations. I did not refine this and you could easily lose the labels and use the names of the individual areas (renaming the headings). I did not try to copy these polylines into a new plan yet but I suspect they would retain the schedule association. RIC As Built V1p.zip 1.99 MB · 8 downloads Thanks for posting..... So far I have done all my SF reports using polylines and schedules. I like to use fill on the plines so I can be sure the edges are where I want them....Different Area types have different fill colors..... I wanted to streamline that task to where I didn't have to spend so much time editing the properties of the poly lines after I drew them if that makes sense. my idea was to create library items, but that doesn't work. I like Rene's suggestion but I am not exactly sure how to do what he mentioned AND I would want to make sure the SF's are figured the way I want them to be. Link to comment Share on other sites More sharing options...
