sea_lyons Posted April 1 Share Posted April 1 Is there anything similar to this door style in any of the Chief Catalogs that I'm just not finding or have not yet downloaded maybe? Link to comment Share on other sites More sharing options...
GeneDavis Posted April 1 Share Posted April 1 Beaded panel doors are possible. Model one yourself using countertop tools, save it as a door, with appropriate stile and rail widths and stretch planes. Beaded faceframe surrounds are above my pay grade. See what one of the cab gurus has to say. I'm sure one will be along soon. 1 Link to comment Share on other sites More sharing options...
robdyck Posted Wednesday at 02:42 PM Share Posted Wednesday at 02:42 PM It's almost certainly faster to make one than to find one. Try this one out. cab door.calibzFetching info... 1 Link to comment Share on other sites More sharing options...
sea_lyons Posted Wednesday at 08:20 PM Author Share Posted Wednesday at 08:20 PM On 4/1/2025 at 7:59 PM, GeneDavis said: Beaded panel doors are possible. Model one yourself using countertop tools, save it as a door, with appropriate stile and rail widths and stretch planes. Beaded faceframe surrounds are above my pay grade. See what one of the cab gurus has to say. I'm sure one will be along soon. Expand I've made other cabinet door profiles with 3D Solids but those were with 90 degree edges, nothing beaded. Maybe I should have tried with countertop tools instead? On 4/2/2025 at 2:42 PM, robdyck said: It's almost certainly faster to make one than to find one. Try this one out. cab door.calibz 217.25 kB · 18 downloads Expand Ahh this is great, thank you!!! Can I ask how you did the beaded part? 1 Link to comment Share on other sites More sharing options...
robdyck Posted Wednesday at 09:23 PM Share Posted Wednesday at 09:23 PM On 4/2/2025 at 8:20 PM, sea_lyons said: Ahh this is great, thank you!!! Can I ask how you did the beaded part? Expand As a startign point, I found a door that was very close. The frame and bead were ok, but it had a raised panel. So I used the delete surface tool to reomve the raised panel and then created a symbol and placed it in plan view. I then added a 3d solid for the center panel and a molding for the detail between the bead and panel. I then select those 3 part and create a new symbol assigned to the cabinet door/drawer category. I set the stretch planes to be centered on the width and height of the panel, and add to my library. I didn't search the library very long, but it still would have been faster to have created the door from scratch. A molding polyline can be used for the outer frame and then duplicated and re-sized for the bead and detail. 1 Link to comment Share on other sites More sharing options...
MarkMc Posted Thursday at 11:29 AM Share Posted Thursday at 11:29 AM Countertop is the place to start as Rob says but I'd do it a bit differently. I'd make the molding a different material than the panel and I would NOT make the door frame until later. Sequence shown here. Counter, Wainscot Cab Door symbol, Wall Cabinet with wainscot symbol in it, final cabinet door, then used in cabinets. Prior to converting to symbol the panel, molding, and the frame each have a different material. When converting to symbol (advanced options) rename each part and set each to use the plan default. Now you have symbols with flexibility. The wainscot panel can be used on the ends of cabinets, it also allows you to make new door symbols with different rail and stile sizes almost instantly, and finally using different materials allows you to quickly make a glass panel door. it can be very fast (as long as you remember to make the back of the cabinet to none or it won't properly become a glass panel door...DAMHIKT) 1 Link to comment Share on other sites More sharing options...
sea_lyons Posted Thursday at 06:44 PM Author Share Posted Thursday at 06:44 PM I did it!!! Thanks all! I use molding lines/polylines quite a bit but didn't realize they could be used to make doors - this is way more streamlined than what I've been doing until now. So much wasted time lol... 1 Link to comment Share on other sites More sharing options...
